Question about Pramac GBW30P Encl Diesel Genset w/Perkins Eng
Can u esplain about trouble shooting in diesel generator
    Novelist:
    Habit-Forming:
  • 118 Answers
This is really a "big" question because there are many kinds of troubles could occur during the running of diesel genset, such as AVR problem, insufficient power, diesel engine troubles, genset exhaust, start and stop trouble, water tank and so on.
Since diesel genset is a big equipment, all its accessories could have troubles.
If you got problem with your genset, I would like to recommned you a website which provides troubleshooting information for diesel genset for different parts.
https://www.dieselgeneratortech.com/support/
Posted on Dec 22, 2018
My 500 kva diesel generetors dosnt work since mornning its workes after 4 houres when the weather changed
Posted on Jan 23, 2010
  • 22 Answers
It may have diodes and no brushes.check diodes
Posted on Sep 18, 2011
SOURCE:
98 diesel Jetta TDI rebuild engine won't start
Did you bleed the injectors, water separator. fuel filter. Is the fuel pump running. A Chilton manual would be a handy trouble shooting guide. Diesel fuel injection is complicated and expensive ( Bosch).
May 17, 2017 | Cars & Trucks
Hino dutro so5c engine slow to pick up speed and now hard to start.
Search Results
    Diesel Trouble Shooting - Flashoffroad
    www.flashoffroad.com/Diesel/troubleshoot/troubleshoot.htm
    Apr 22, 2003 - Trouble shooting the GM 6.5 diesel engine in Hummers and GM trucks.... and the crankshaft position sensor that will cause a hard or no start condition. ... a pin hole in the system between the tank's pickup and the fuel pump. ... I had a highspeed (60 mph) surge on a 99 td where the rpm would jump up and ...Missing: dutro ‎so5c
    Light-Duty Diesel Diagnosis - Auto Diagnosis Repair Help
    www.aa1car.com/library/diesel.htm
    That's why diesels continue to be a popular option in many pickup trucks ... by the cold oil can reduce cranking speed to the point where the engine may not ... Problems in any of these areas can make any engine hard to start. ... If slow cranking isn't the problem, perhaps there's something wrong with the .... Need Help Now?
    05 international 4300 series power problem - Diesel Mechanic Jo
Jan 18, 2016 | Cars & Trucks
Why unit keeps shutting down after it starts.
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
Apr 26, 2015 | Kipor Generator Diesel Kde5000ta
No charge
You'll need to test to see if you are getting voltage from the brushes. This is a live test so, using something like alligator clips or such on the metal bracket of the brushes for your volt meter is a good idea. Simply start your generator with the volt meter leads attached to the the brush holders or exposed electrical connection to the brushes and see if they are producing electricity (120vac or greater). No voltage then it's your brushes, field, or stator. If they are good check the output of the voltage regulator. If it to does not kick down any voltage above 120 then it's your problem.
Note most cheap generators do not have a voltage regulator. All generators depend on the correct engine rpm to achieve normal voltage. 3600 rpm is the correct speed on a two pole generator to produce 110 to 125vac and 60hz (normally found on gas generators). 1800 rpm is the correct speed for four pole generators (normally found on diesel generators). You may set your rpms slightly higher to ensure that it's maintained underload ie 3750 for gas. Diesels usually have very good governors and don't need to be set higher.
Mar 29, 2009 | Coleman Powermate Powermate 5000W...
Generator produces no power
Glad to hear it was easy :-)
Here is a link to my trouble shoot solution so that this will get marked as solved.
Feb 24, 2009 | Coleman Powermate Premium Plus 6250W...
10 kw deisel generator in sailboat suddenly stopped generating,
Are you still looking for help with your Gen. ?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jan 30, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
372 people viewed this question
Top Pramac Electrical Supplies Experts
Marvin
Marvin
Lawrence Oravetz
wadingriver
wadingriver
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
