Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Posted on Dec 31, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frost on ice maker
I have a side by side whirlpool refrig/freezer. It is 12 yrs. old. It works great; however, the area where the ice comes out of the ice maker is freezing up. It has TONS of frost on it and then the ice won't come out the door. The ice maker works great. I've taken out the ice storage/maker and defrosted it many times but the frost keeps coming back. Any suggestions? Thanks!!
-Nicole
  • nikatnight Jan 04, 2008
    tech17,
    Thanks! After looking at the door closely. It was not sealed well. Manually, if I push it shut, no frost is formed but if I don't do that the door won't shut properly and frost appears. How easy is it to replace? Where do I get the part?
    Thanks again!
  • mary8241 Jan 12, 2009
    I have the same problem but I can see that the door is not attached as it should be how easy is it to fix this problem
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Dec 31, 2007
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
897911
Points
3823
Look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Freezer compartment has frost buildup
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
1helpful
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
3helpful
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
1helpful
My old whirlpool refrig. with frostless freezer on top model # ET20DKXSN 00 has started to form frost in the back of the freezer where the ice cube trays are stored. It seems to be coming from the around...
check the back of the refrigerwtor there shpoould be a opening where the water goe into the freezer for the ice maker. you need to seal it up so that the moiust air from outside does not enter the freezer.
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
