Hi
Oily beans (shiny) can some times stick together after grinding with a fine setting. Try opening the grinder setting to the very coarsest setting and see if it will clear the passage. If you have pushed the brew button an lot of times you may have packed the grounds in the passage which will have to cleaned manually.
Once you have the grinder working again, open it to the coarsest setting to clean the burrs. 1 time is enough. To turn the grind setting back down to your setting make sure that the grinder is running at that time. You can open to a coarse setting any time but it has to be running to finer.
