Computers & Internet Logo
Posted on Oct 25, 2009
Balck color turns into green
My is a avixo lcd monitor, there are a lot of green dots coming out, they change the dark colors with green one..
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Oct 25, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
5448
Points
35
Are the dots appearing in diagonal lines or randoml across the screen? This would suggest to me either a loose connection in your cable or the screen is faulty and will need replacing. Sorry for the bad news
My monitor fell on the floor and now my color is off. the color is darker on the left of the screen. Do I need a new monitor now?
I suggest you to buy a new monitor because it will be expensive to replace the LCD. You monitor LCD is damage that is reason why there is a dark color on the left screen.
To avoid any harmful accident in the future. Because it will create electrical spark inside the monitor which will be burn out the entire monitor or maybe result to smoke. There is no remedy in that particular trouble but to replace the entire LCD. But this is not advisable because it will cause you expensive cost of repair.
You need to buy new monitor and I suggest if you buy new monitor. Buy LED monitor which is better than LCD. LED monitor is a green campaign of every manufacturer due to energy saving specification and have a better graphics than LCD...
Hope this will help you a lot. If you any other question please don't hesitate to contact me
The screen has a dark green tint and cannot be adjusted. More specifically, the green section of the RGB setting on the monitor can't be changed (the G setting is permanently gray and I cannot move to that...
Take it in for repair seems to me that you have done all that you could to fix this monitor it is a flat maybe worth the repair if the repair is slightly less or more I would consider spending the green on a new one they are getting down in price. Thanks for using FixYa! John
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
2helpful
Screen blacks out, but power light stays green. I can repress the power button and it will come on for a short while
Power supply, replace the caps, 220uf,470uf,680uf. you will see the tops of them are popped out, check the board too see if its turning color from the surface mount transistors that drive the lamps..If its turn an very dark color the parts have been very stressed out..
My nokia display screen looks black on one side and colored dots
your display has broken.lcd are made of glass,its easy damage when phone is droped.must change display in service
Sony a100 distortion dots - Im getting several
If these are single pixels on the LCD screen, they are normal. From pg. 8 of the user's guide:
"The LCD monitor is manufactured using extremely high-precision technology so over 99.99% of the pixels are operational for effective use. However, there may be some tiny black points and/or bright points (white, red, blue or green in color) that constantly appear on the LCD monitor. These points are normal in the manufacturing process and do not affect the images in any way. "
This may also be helpful.
"images may trail across the LCD monitor in a cold location. This is not a malfunction. When turning on the camera in a cold location, the LCD monitor may become temporarily dark. "
Samsung SyncMaster 730B monitor green color problem
video controller card has gone bad need new video controller card.
GREEN DOTS
Try adjusting the resolution on your monitor or the color. Make sure that the resolution is also adjusted properly in your computer system.Hope this helps and if it doesn't please let me know
Monitor dark only when display PC, normal TV
hi have you checked your PC output? check it with another screen (whichever) and see if the output signal is good if soo check the cable and connections to your LCD check your PC for software configuraitions: 1) TV output 2) good resoulotion 3) media borad is strong enough to handle this LCD if all is good then maybe the TV borad is sending a low voltage/current then the LCD can see good luck
Grand Canyon Tech
Grand Canyon Tech
