The seat bottom has two 12mm bolts on the drivers side and pass side behind the seat between the seat back and bottom, feel between the seats and you can feel them, use a 12mm shallow socket and 12 inch 3/8 drive extention to remove them, them push the relase latches on the front of the seat bottom.
Testimonial: "Thanks I was looking for a quick release somewhere I did feel the bolt heads and hoped that wasn't it"
Is this for 2009 sonata too
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedure
Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement .
Nut, Rear Seat (Qty: 6)
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N?·m (33 lb ft)
Bolt, Rear Seat (Qty: 3)
Tip
