Question about GE WPRB8050D Top Load Washer
How do I remove the front panel of a ge profile washer wprb8050d
    New Friend:
    Problem Solver:
  • 12 Answers
Many GE washers have the front panel held on by two clips on the top edge. Take a stiff putty knife and insert it about 6" from the outside edge and smack it firmly. The clip should release. Do this on both sides. Pull the panel away, then lift it out of the bottom lip.
Posted on Dec 20, 2009
  • GE Master
  • 5,569 Answers
That may not be possible; many units have connected front and sides that are removed as one piece by removing hardware in the back and inside the washer.
Posted on Oct 24, 2009
SOURCE:
Wiring diagram of pressure switch
All Ge washers should have a wiring diagram inside the control panel on the left side if standing in front of the machine. Hopefully it wasn't removed by someone.
Apr 01, 2015 | GE WPRB8050D Top Load Washer
Ge wprb8050d
when it stops filling
you fill it with a jug of water to the right level
then see what happens
if it goes past rinse
have a look at the water valve it needs to be changed
Jan 21, 2014 | Washing Machines
Ge profile front-load washer not draining
Firstly took the bottom front panel off and removed the drain plug/trap. Then the problem should be solved easily. For More information please visit Clothes Dryer Element .
Sep 22, 2012 | GE White Profile Series 15 Frontload...
GE PROFILE wprb8050. agitator will not spin. I removed and found the coupler is moving left to right, just will not turn agitaor. it appears to be loose? any suggest?
If you can easily spin that agaitor coupler free by hand..its stripped and needs to be replaced. The part number for it is WH49X10042 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwanger.com
repairclinic.com
GENE
Aug 30, 2011 | GE WPRB8050D Top Load Washer
How do i remove the lid on a ge profile harmony washer?
Use a putty knife to remove the front panel first/
The putty knife will insert between thr top of the lid and the front panel about 2 inches in from each side.
The panel will pull forward then up to remove it.
Then remove the screws holding the lid down.
You may have to open the control console to remove the lid.
Apr 03, 2011 | GE Profile WPRE6100G Top Load Washer
My GE Profile WPRB8050D fills, drains and spins but won't agitate. It makes a sound, but doesn't move. What could be the problem?
These washer have a motor that runs clockwise and counter clockwise...for agotaion it runs one way and for spinning it runs the other...check if the motor is still getting power, but not running in the one direction...motor is probably bad...
heatman101
May 02, 2010 | GE WPRB8050D Top Load Washer
I have a ge top load washer that the tub is off balance.
Open the control panel to get the mini manual. It will show how to remove the front panel and check the tub supports.
Feb 15, 2010 | GE Profile WPRE6100G Top Load Washer
GE WPRB8050D Top Load Washer Logo
383 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
