Acer Aspire 5315 Notebook Logo
Posted on Oct 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Randomly freezes or completely shuts off
Acer laptop that randomly freezes or completely shuts off, it is not getting to hot but don't know why it's doing this
Anonymous
Level 3:
  • Master 601 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
Answers
601
Questions
0
Helped
119489
Points
1632
Check the computer for virus and spyware.
Thanks
Acer 4920 randomly restarting
might not be the fix but try getting the hover and where the fan outlet is give it a good hover the fan can get blocked and this will make the cpu shut down when it gets to hot
My acer 5750 i7 keeps shutting down
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
For an instant fix use system utility tool Reginout.
WebRepOverall ratingThis site has no rating(not enough votes)
Acer aspire one d257-13608 freezes randomly
It's likely to be the BIOS that needs updating. Full solution and link to get the stable BIOS flash is here:
http://blog.robkershaw.com/2012/01/acer-aspire-one-d257-freezing-issue.htmlhttp://blog.robkershaw.com/2012/01/acer-aspire-one-d257-freezing-issue.html
2helpful
It shuts down about a minute after you start it the acer aspire one
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
I have an Acer Apsire 6930 and a few weeks ago the screen went black and the computer will not boot. I ordered and received the recovery discs from ACER, but the computer won't even boot/run from the...
Most probably the intergrated Graphic on the mainboard of your Laptop is faulty. Too bad, you have to replace it from ACER or any authorised Vendors.
If the cost is too expensive to repair, get a new Laptop/notebook.
I have an Acer Aspire 6530 running Windows Vista and today it started shutting off at random. When it shuts off the bottom 2/3 of the screen has blue stripes across it, and on the blue is text I cannot...
Good question.
Does the computer feel hot when it shuts off?
Does it always happen at the same exact time?
Can you try booting the computer into Safe Mode? (What Happens?)
First thing I'd try is uninstalling the video adapter driver under device manager and restart the computer.
Let me know what happens!
My acer aspire 1690 suddenly shuts down randomly. is not an overheating problem I'm sure. I have also been checked by a technician but can not find the solution
Hello, the major reason of laptop randomly shutdown is Overheating, you said it is not over heating...
I will suggest you couple of things that you can try:
1) remove the battery and plug the laptop on direct power supply, then place the laptop on a flat and hard surface and then boot the laptop.
or do a complete virusscan of the laptop.
or reinstall the OS...
Can i just throw my computer?
can you can do a virus scan and then a disk defrag
update windows
that should help you
make sure when your on its well ventilated if it's getting overly hot and shutting down could be another prob
i have had laptops that do get really hot
does it do it only when you have AC power plugged or even when your using battery
Mouse keeps freezing
It maybe getting too hot. You need to blow out all vents and fans. I have seen acer laptops get too hot, easily, so you need to make sure it is dust free.
G'luck
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
