Question about Philips 51PP9100D 51 in. Television
Crack inside of screen
I have a Philips DLP TV and I found a crack on the screen, but can't feel the crack it seems to be on the inside of the screen. Can the screen be fixed or is the screen be replaced
    New Friend:
  • 127 Answers
This screen has multiple layers of plastic before you get to the main screen, if the picture isnt affected, you've only cracked oneof the plastic pieces, these are cheap to replace
Posted on Dec 31, 2007
6ya staff
SOURCE:
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
How to fix a broken screen? How much will it cost?
Sorry. The replacement screen is nearly as expensive as the TV. It probably will cost more to fix than the TV is worth. Just do the correct thing and look for a new TV!
Apr 09, 2010 | Philips 37PF9975 37 in. HD-Ready Plasma...
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
I have a RCA HD61LPW42 . I recently replaced the lamp but there seems to be a dull/dark spot on the TV screen where the color is always a dingy brown. when I replaced the bulb I noticed that it had...
Most likely you also have a bad Optical Block assembly. Do to the cost of the part, I would not invest the money to replace it. The Lamp failing would not cause this to happen.
I hope this helps,
Skyassoc
Oct 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Samsung DLP made a "pop"
Sounds like your color wheel was warped and finally cracked and broke.
Jun 26, 2009 | Samsung DLP HL-P5663W 56" TV
Crack on the inside screen of my 42" Philips Plasma TV
This is a known problem with Philips. If you keep on them they will work with you. Another option is call a repair shop in your area and see if they can help you out. Sometimes a repair shop will help out if you allow them to do the service if they are able to get Philips to pay for the repair.
Good Luck
Apr 21, 2009 | Philips 42PFP5332D 42 in. Plasma...
Plasma work fine but outer screen cracked.
it's hard not seeing the 'crack' but basically a real crack will allow the (plasma) gas to escape. if that happens just forget it and buy a new one if out of warranty.
if it really seems as tho there is a crack in the glass, I would just enjoy it while you can, and try not to ever move the TV as it may totally go at that point.
if under warranty get a tech out to the house before it expires. make them come out in this case rather than bring it in for the aforementioned reason.
Feb 11, 2009 | Samsung DLP HL-P5663W 56" TV
Philips 50" DLP Problem
I would need to know the model number of the DLP to offer any worthwhile advice. Is the set still under warranty from phillips? If so I would get warranty involved before it runs out DLPs are expensive to repair.
Apr 08, 2008 | Televison & Video
Black screen
You have a cracked panel and the gasses inside have escaped. The buzzing noize you are hearing the the current flowing throught the panel. It will be cheaper buying a new TV than buying a replacement panel. But if u wanna check out the price look up your model on parts.com
Apr 04, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 51PP9100D 51 in. Television Logo
2,458 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
