Televison & Video Logo
Posted on Dec 31, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
26LA30Q32LA30Q Hello, Just received the above model for Christmas. My granddaugter scratched it with a key. There's a scratch line on the left side of the screen. HELP!!!!What can I do?
  • veenie Dec 31, 2007
    The actual model number is 26LA30Q, meaning it's a 26 inch television.
    Thanks for your input
TV Doctor Repair Consult
Level 3:
  • Master 373 Answers
  • Posted on Dec 31, 2007
Master
Level 3:
Answers
373
Questions
Helped
93042
Points
1011
If it is a glass screen there is nothing you can do to it. First the tube is not available and second too costly if it was. Third the only chance is a used tube from a junked out tv at a repair shop and that will cost too but not as much. But seeing that it is a CTC 179 and assuming the long number is the serial number, it will be hard to find. If that is not the serial number then I'm sorry for I am completely wrong! If it is a lcd tv then the screen cost usually about three quarters the price of the set. Sorry about your problem. Hope this helps At this point I am assuming from deductions that it is a LCD.
The outer skin on the freezer door is scratched. Is there an inexpensive fix to replace the outer skin on model 10651123210
If the scratch is on the smaller side and not a deep gouge, you should be able to obtain touch-up paint for the appliance. These products are usually available at Sears appliance parts depots or more generically at home improvement stores.
Why is planer leaving scratchs in wood after changing the blades
1. If the scratch is on the side not being cut, check the infeed and outfeed tables for debris or defects.
2.. If the scratch is on the cut side of the board:
(a) check for problems with the rollers and any parts that hold the board down while being planed. (b) check for nicks in the blades. Shift the blades a little left and right so the nicks don't line up; or (c) hone and reset the blades.
2answers
Won't recognize the disc as a game... how do we fix this? Its a brand new Wii game.
Check the bottom of the Game Disc (the side without any labels or writing) for any dirt or damage (such as cracks, scratches, etc.).
If the games look significantly damaged, such as with scratches or cracks, it will need to be replaced.
If the game looks dirty (fingerprints, smudges), try cleaning the Game Discs. If the problem persists, the Game Discs will need to be replaced. or Click here to download repair guide
Is there a way to clean a Sharp fax machine? Unsure of model # as i am at home and it is at work. Persons receiving faxes have a dark, 1 1/2 inch wide line along left side of fax so unreadable.
YOU HAVE PROBABLY GOT TIPPEX ON SCANNER. TRACE PAPER PATH TO SCANNER AND CLEAN IT WITH SOME METHS. DO NOT SCRATCH OR IT WILL SHOW FOREVER. SCANNER IS ALWAYS THE FIRST THING PAPER GOES INTO AFTER IT STARTS TO MOVE. IT LOOKS LIKE A LONG PIECE OF GLASS.
2answers
Ps3 scratched my game i think
Go to CDFixers.com. They will professionally refinish your disc for $1.95 and it will look brand new. Good luck!
2helpful
Cd broken what do i do
How do you mean broken, is it scratched, cracked, dented or literally broken?
If it's scratched you can get it repaired quite easily. Anything else and I'm afraid it is probably history. Check out below:
Check to see if there are any scratches on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs.
Most Game Discs, DVD’s and CD’s can be fixed quite easily. Some home remedies may help with very light scratches on some of these discs but a professional disc repair service is usually required to repair any discs with more than very light marks or scratches. Discs can normally be repaired back to a virtually new condition.
For further help on disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If you tried some home remedies and they have not worked, try sending the disc off for repair, it’s normally the price of a standard letter, if the disc is sent as a letter and properly packaged. There may be a local disc repair service in your area. If not, contact the site above for advice on repair and shipping.
Hope this Helps!!!
Line on left side of printed page toner has been changed and did not fix problem
A line there might not be the toner but the laser drum unit.
The operation below is dangerous - on warm printers you can badly burn yourself, and on all printers you risk severe damage to the drum, requiring replacement.
Opening the printer should show both the toner unit and the drum unit, with a usually green metallic drum cylinder. Taking the utmost care never to touch the drum with your fingers, extract the drum unit and check for anomalies on the RIGHT (where the left side of page goes) side:
- scratches: unfortunately, nothing to do. Drum replacement is your only option.
- black sooty lines: wipe them with a clean, dry, lint-free paper towel. Usually caused by:
- small specks of dirt lodged between the drum and the drum shell. You can remove them with a wooden toothpick. Never use anything sharp near the drum, it scratches very easily and scratches aren't repairable. Sometimes it is possible to raise slightly the shell so that a gap appears between shell and drum, and a folded dry lint-free napkin can be shuttled back and forth to clean the groove from dirt and ink clots.
Replace the drum and print two test pages. The first will usually be very dirty because of the toner loosened in the drum.
A scratch on a new car.
At large auto parts stores, there is a wax product, color match , that works well. Also a reputable body shop should be able to buff out the scratch.
1helpful
Xbox 360 motherboard scratch.
Hello jbitwa, To determine if the scratches will have messed up you motherboard you have have to determine where the scratches are and what is scratched up. Now if you just scratched up the green motherboard (no circuits [lines cut open] and no chips [blocks]) you should be fine. But the only way to truly tell is if it will turn on when you plug everything back in. Now the processor board is small and efficient but there is still room on there for someone to scratch and still allow forgiveness.
I look forward to your post to see if it still fires up.
Nec plasmasync 4200w 3 vertical lines one yellow two purple
Sorry to tell you, it is not a scratch, but a bad cable connection from the driver IC's, connecting up the plasma screen to the drive board, or the drive IC for that section of the screen is defective. It is not a repair a user can do as there are no user replaceable parts inside this set. Your going to have to call NEC or an experienced Plasma repair shop.
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
