You can easily fix the issues with the Internet Explorer closing in your computer by checking the reason for the issue. If the issue is caused due to any installed plug-in, you can remove the plug-in from all the unnecessary or trouble creating plug-ins installed in your IE8. If you have malware issues in your computer, you can install a good antivirus program in your computer. Then you can scan and fix all the malware threats in your computer after updating it. The issues with your temporary files can be fixed by deleting all the files in your temporary Internet folder. If you have any file corruption, you can perform a repair installation after fixing all malware threats in your computer.
http://browser.iyogi.com/internet-explorer/internet-explorer-8-keeps-closing.html
Hope this information helps you.
Try reseting all IE8 settings back to default, this microsoft KB artical will guide you threw the steps.
http://support.microsoft.com/kb/923737
If this failed I would suggest un-installing IE8 or performing a repair install.
Cheers,
SOURCE: why do i keep getting DEP error message each time
You can disable DEP by following these steps:
Disable Data Execution Prevention (DEP) completely
This setting does not provide any DEP coverage for any part of the system, regardless of hardware DEP support.
WARNING: Be sure to enter the text carefully. Your boot.ini file switch should now read:
/noexecute=AlwaysOff
Verifying DEP is Disabled
Thank you!
Sabharish
