Sony Ericsson K300i Cellular Phone Logo
Posted on Oct 24, 2009
I cannot access the internet using my phone's wap. my settings seem to be not updated. what should i do?
1helpful
My E72 keeps on saying data package active and connecting to the internet, MMS and wap. I tried stopping active connections, but after a while it starts connecting again. I have switch off the phone and...
Maybe your Packet data conn. was set to "When available"
Go to Tools->Packet Data and select the Packet data conn. and change it to "When needed"
Hope this helps.
21helpful
How to get internet setting samsung GT-B3410?
you have to need GPRS and WAP setting in your Mobile Phone to use your internet settings To get your internet setting you need to Call your Service Provider and just say then to Send the GPRS and WAP setting then they will send you the Setting to your Mobile phone and you have to Save then and set as Default and and you have to Re-Start the Mobile Hand Set and then You can Access The Internet In your Mobile Phone
I have a problem accessing internet, is there any technical support for it. what is the manual settings? my phone has mms,wap and internet settings. can i access internet using GPRS? what manual settings...
Your cellular provider can answer all of these questions.
Call them from another phone so they can show you the features and answer questions about your cell phone without being cut off.
Good Luck!
Mar 06, 2010 • Cell Phones
7helpful
NEED TO CONFIGURE THE INTERNET SETTING,
To get your Glo 3G internet settings, you will send SMS activate to 444 using a 3G mobile phone. Save the internet settings in your mobile phone. To get Glo WAP settings, SMS your phone name and model to 927. e.g, to activate Nokia 2630, SMS Nokia 2630 to 927. Save the internet settings in your mobile phone.
Glo manual 3G/3.5G internet settings
Service name: Glo 3G
IP Address: 10.100.98.22
Port: 3130
Username: wap
Password: wap
Access point name (APN): glo3gvideo
Authentication: Normal
Home page: http://cms.gloworld.com
6helpful
I have bpl sim card,i want to know setting for using wap internet on my mobile 5300
Hi i was reading regarding WAP settings for BPL mobile...I have copied and pasted what i saw from different forums...see if it is of any help
you can manually conigure GPRS in your mobile phones.
BPL_WAP
homepage http://wap.mizone.bplmobile.om
Session mode permanent
connection security off
data bearer gprs
gprs access point mizone
IP address 10.0.0.10
authentication type normal
login type automatic
BPL_MMS
data bearer gprs
For those who are interested in using GPRS facility provided by BPL Mobile (Mumbai only) here are the brief n settings required for it. You can also use this for surfing Internet through you PC provided your PC is connected to your mobile using Data Cable or preferably BlueTooth.
Go to the main menu and open “Settings”
Select “Configuration” and then “Personal Configuration Settings”. Create a new configuration settings by selecting “Add New” from “Options”
The account fields should be filled as below:
Account Settings Account Name : bplweb
HomePage : http://wap.mizone.bplmobile.com
User Name : Your mobile number
Password : bplmmsc
Use Preferred access point : No
Access point settings : As given below
Access point settings Proxy : Enabled
Proxy Address : 10.0.0.10
Proxy port : 9401
Data bearer : Packet data
Bearer settings : As given below
Bearer settings Packet data access point : mizone
network type : IPv4
Authentication type : Normal
Password : bplmmsc
Now once you have done that get back to “Personal Configuration Settings” select the new account “Bplweb” that you have just created and go to “Options” and click on “Activate”
Go back to the main menu and open “Settings”
Select “Connectivity” and then “Packet Data”
Set the “Packet data connection” to “When needed” and then click on “Packet Data Settings” then “Edit active access point” and then set “Packet Data Access Point” to bplgprs.com
These instructions are according to the Nokia sets 3110c, 6085 and should not differ much for other sets and brands and in case of which you can always go to the customer care as did.
BPL WAP SETTINGS FOR MOBILE PHONES
Connection name:- BPL WAP
data bearer: packet data
Access point name: mizone
User name: 919821099800
Prompt password: no
Password: bplmssc
Authentication: normal
Homepage: http://wap.mizone.bplmobile.com/
ADVANCED SETTINGS
network type: IPv4
Phone IP address: automatic
DNS address: automatic
Proxy server address : 10.0.0.10
Proxy port address : 9401
Hope this helps !!!
Apr 17, 2009 • Cell Phones
Internet connection
hello there! thanks for using Fixya.com!
I suggest that you should contact your Network Service Provider. Usually, WAP application is already featured from your mobile phone but you should activate it the GPRS to access the internet. Please check with your Network Service to send you this setting manually or over-the-air!
This application WAP browser provides all of the basic services of a computer based web browser but simplified to operate within the restrictions of a mobile phone, such as its smaller view screen. WAP sites are websites written in, or dynamically converted to, WML (Wireless Markup Language) and accessed via the WAP browser.
Hope this will help!
2answers
Unable to access Internet using GPRS/wap
sorry no can do with those clone phones try your mobile service provider
31helpful
5answers
How to activate vodafone live india in HTC touch P3452?
vodafone live setting for windows based mobiles version 6::::
select "start" ---->>> select "settings" ------->> select "connection"----->>> select "connections"
Now Select "Add a new modem connection"
Connection name::"Give any name"
Moden:: select "Cellular line (gprs)"
Select "Next"
Access point name:: "portalnmms"
select "Next"
Username:: (blank)
Password:: (blank)
Domain:: (blank)
Select "Finish"
Now Select "Setup/Edit my proxy server" below that "Add a new modem connection"
Select the two check boxes
1.) This network connects to the internet
2.) This network uses a proxy server to connect to the internet
Now you ll have proxy server box below that you will have "advanced"
Select "advanced"
Select "HTTP" --->> Server:: "10.10.1.100" port:: "9401" select "ok"
Select "Wap" ---->> Server:: "10.10.1.100" port:: "9201" select "ok"
Give ok to all options.
Now select "start" select "internet explorer" and try it for the connection...
When internet is connecting it ll show "Connecting to GPRS"
You ll be getting "locating" and "opening" and the webpage
2answers
Wap settings for motorizr z3
Regular rogers wap
(not using phone as modem)
uses navigate plans
http://www.shoprogers.com/store/wir...ng/overview.asp
apn: goam.com
username: wapuser1
password: wap
IP 208.200.067.150.
or
172.025.000.107
Rogers Media settings
(for MMS/PICmessaging)
http://www.shoprogers.com/store/wir...remessaging.asp
apn: media.com
username: media
password: mda01
mms.gprs.rogers.com
ip 172.025.00.107
Rogers internet.com settings
(to use phone as modem. Or is needed for HTML phones, or wap 2.0 phones at this current time.
requires access to a Data access plan
apn: internet.com
username: wapuser1
password: wap
ip: same as goam, 208.200.067.150
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
