Question about Frigidaire PLEF398AC Electric Kitchen Range
Frigidaire---oven door locks.
I tried to lock the oven door the other day, and tugged on it to see if it was locked yet while the door lock light was flashing and it locked while the door was open. Now the lock light is still on and the door opens, but the oven won't turn on now. How do i fix this issue?
  • 1 more comment
  • Alliey Dec 31, 2007
    tried it, but it didn't work...oven lock light is still on, now everytime i open the oven it beeps....
  • Anonymous Mar 19, 2008
    what is the lock for will oven work with door locked
  • kite05 May 11, 2010
    I have a Frigdare stove fef375chsa need to no how to turn lock door off
    New Friend:
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Posted on Jan 27, 2010
    President:
  • 1,314 Answers
Open door push in on the door switch and hold it hit clean while holding the switch count to ten then cancel holding the door switch its the one that turns the oven light off when the door is shut
Posted on Dec 31, 2007
  • robert samples Dec 31, 2007
    go turn your breaker off for ten seconds then on
I tried the door switch routine, and I tried turning the breaker off for an hour - no luck.
With power on, the stove was making a "rattling" sound, as it tried to unlatch, but couldn't.
With the breaker on, I tapped the door latch with a hammer (lightly!) to the left. It slowly moved to the left, and the "door locked" light went out.
BAD DESIGN!
But at least I can cook for 8 on Saturday.
Posted on Apr 09, 2008
SOURCE:
Oven is stuck in lock mode
Hi Lora, this is AP!
Based on the description of the Frigidaire electric range provided it appears the door lock feature has been activated. In order to cancel the Oven Lockout feature, press clear off and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing clear off and holding for 3 seconds. "Loc" will appear in the display, the "Door Locked" indicator light will flash and the motor driven door lock will begin to close automatically. Allow about 15 seconds for the oven door to lock. Once the oven door is locked, the current time of day will appear in the display. If any control pad is pressed with the oven lockout feature active, "Loc" will appear in the display until the control pad is released.
This information is also located in the owner's manual should you like to view it again, you may retrieve a manual using your model# and the following link http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/.
I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Mar 17, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
Frigidaire FES367FCC. Oven is flashing F90.
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2010 | Frigidaire FES367 Electric Kitchen Range
My frigidaire gas range has a F90 on it when I tried the self cleaning oven feature
unplug the range.
wait 1 minute.
wait 2 minutes.
Feb 16, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire electric drop in oven has blinking door locked light on. F9 error message. Tried to self clean, oven never got hot, door locked and can't get open. Been 2 days. Self clean light will not come...
http://b2b.frigidaire.com/support/manuals.asp
this is a free download site from frigedaire if you have your model number you can download your complete manuel i was unable to find the F9 code for an oven
but suspect it has to do with door lock switchs if you can download your manuel from site it may help you can try shutting off breaker for oven and see if it will reset
good luck ron
Dec 11, 2009 | Ovens
Beeps - won't stop - f90 code - thinks door is locked.
unplug the range.
wait 1 minute.
wait 2 minutes.
May 23, 2009 | Frigidaire FGS365EC Stainless Steel Gas...
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Frigidaire Wall Oven does not open once hot
Well at least I seem to have solved it. I kept hitting clear off and tugged on the door and it finally opened. Once opened I noticed there is a metal hook at the top of the opening to the oven. Mine was rotated to the 9 o'clock position. I took a pair of pliers and rotated it until the open part of the hook was in the 12 o'clock position and tugged outward on it just a bit and the "door locked" signal went off. I hit clear off again and the beeping has not resumed. I'm thinking the hook got partially stuck in the wrong position after it automatically locked the door for cleaning.
Waiting for the oven to completely cool off before I close the door again.
Hope this helps someone else out there!
Dec 17, 2008 | Frigidaire GLEB27S7A Electric Single Oven
Frigidaire PLEF398AC Electric Kitchen Range Logo
2,287 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
