My frigidaire front loader washing machine does not pump water out of the tub, everything else seems to work just fine . The door locks (and hums loudly) and lock light works, turning the cycle knob has no effect except lock the door when turned on. Motor does not run but I can turn the tub freely. The belt is in fine shape.
Sounds like you have something in the pump and if there is a filter it might be dirty.
You will want to unplug the machine and take the back panel off and pull the pump out of the machine.You might want to take it outside an do this since there will be water in the machine and will make a mess.
If there is a filter it will be located behind the front panel below the door.There should be two or three screws that hold this panel on.They will be easy to access from the front with a screwdriver or a cordless drill and should be a #2 philips.
SOUNDS LIKE THE WASTE PUMP IS NOT WORKING .
