Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly. Check your configuration level and access policy. If its a public server you have to place it in DMZ. Check IP settings of the server. U may require a VPN tunnel Rate if this is helpful Thanks Good Luck
Do you have an email server in place? If so, you need to setup port 25 for inbound access to the IP address of the email server. I would suggest that you don't allow all as that will open up everything and kind of negates the reason to have a firewall. Some ISPs block port 25 though and use port 587.
If you don't have an email server then the problem might be with your email client configuration.
With the unit on, locate the small reset switch on the back of the router. Insert the end of a paperclip into the reset switch and hold for 10 seconds. The router will restart itself and the WLAN light will stop blinking. The router is now reset to factory defaults.
Remember The factory defaults username is admin, and there is no password.
this will not be a problem of your firewall. it will almost certainly be a password problem. ftp uses ports 20 & 21 but if you have disabled the firewall this cannot be the cause.
Possible problems:
1. IDE Flash device is damaged
2. IDE controller is damaged
2. Firmware is corrupt
Try and download the firmware, and install. You should then get a better idea if the IDE device or controller is bad if it won't install or see the device.
