If you can her it clicking that is a good thing can you see the blue spark between the electrode and the burner? some times cleaning knocks these little electrodes out of line or plugs the tiny holes directly in line with the spark ( try a tooth pick to clean out the holes) Good Luck
some times you can hear it clicking and some times you can see the blue spark but only on one side I would suggest that the wireing going to the igniters on the right side has become compromized maybe just un hooked or loose and the igniter is grounding out underneath the cook top some where pull the burner elements out (usualy just a 1/4 turn to the left) and have look inside if its both elements then it's probably a the junction point for those two elements Good Luck
Tried cleaning - didn't work. I can see the spark on left burners but not the right side. The left burners will light once but will not light after that.
