You did not state the Make/Model but this is a Ricoh/Savin/Lanier/Gestetner failure code so I will go with that.
SC320 is a laser mirror motor failure, also referred to as the laser scanner. Most likely this code will not reset, but I would at least try powering the machine off then on to check. If not, I am sorry to say this will require a trained service technician to replace. Parts and Labor approximate cost should be around $360 depending on model.
Good Luck and sorry again to be the bearer of bad news.
Call for service or trash it.
