When the tub fills up it overflow the top of the tub
Its the over fill valve blocked or its packed up on you, if you take the top of or the back and look inside the washer you will see a small thin pipe coming from the bottom of the drum to the top of the vave block pull it off and blow down it to clear any muck in it it should work after this is done
The water level switch is not being activated. Remove the top (look for screws in the control panel sides) and check for a tube that comes up from the bottom of the outer tub and has a switch module mounted at the tube top.
