No matter how dark the contrast, if the room is dark you will be able to read it well enough to get to the settings -that is unless the display is burned out altogether
The Robinair 34788 is an automotive air conditioning service machine that features a large, easy-to-read display. If the display on your 34788 machine appears dim or the contrast is not suitable, it is possible to adjust the display contrast to improve visibility. Here are the steps to adjust the contrast on the Robinair 34788:
Turn on the machine and wait for the display to fully light up.
Press and hold the "Enter" and "Clear" buttons simultaneously for three seconds.
The display will show "Contrast" and the current contrast setting.
Use the "+" and "-" buttons to adjust the contrast to your desired level.
Once you have set the contrast level, press the "Enter" button to save the setting.
The display will show "Contrast Saved" to confirm that the new setting has been saved.
If you are still experiencing difficulty with the display after adjusting the contrast, there may be an issue with the machine's internal components or the display itself. In this case, it is recommended that you contact a qualified service technician for assistance.
Right click the display go to properties and on the advance tab try reducing or advancing the refresh rate to see if there is a difference. If negative restore the rate to the original setting. Good Luck. Ed Pinero
If the display is too light or too dark, you should adjust the contrast of the display.
Press either review button until NO CALL or the number of calls displays. Press and hold the READ button approximately 5 seconds until the display reads CONTRAST followed by a number. Release the READ button and use the review up and review down buttons to change the contrast number. When you are finished, press READ again.
Install a new firmware, or When installing the FCU, slowly and carefully connect the MBU to the FCU to ensure a proper connection. ! If the connection is not properly established, the fax option may not be detected and/or SC820 may occur.
hi if u cant find any bit of paper in paper path may be any path sensor out of order or may be dusty sensor just clean the all paper path sensors
thanks
u have to go sp mode and clear the memory. to enter sp mode press the yellow botton once and press 107 and hold down the the red botton after some seconds it will enter the sp mode move to 5 mode scroll to clear memory and press ok
Hello Jinx55, the problem is the display unit itself or the cable that goes from the display to the electronic (Most likely the dispaly itself). The display will need to be replaced. You can contact Miele directly at
(800) 843-7231
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
