Question about Uniden Lands Phones
I have uniden exa 915 . Problem: When you pick up the cordless hand set and push the talk button you get a beep,beep,beep and but no dial tone.I put a new battery in two mo. ago and just to make sure I put another one in a few days ago.What else can I do ?
    New Friend:
  • 90 Answers
Its lost its "link" to the base unit, you need to re link them this is either dont thru the menu system on the handset or pushing a button underneath the base unit and THEN re linking it via the menu.
Posted on Oct 23, 2009
SOURCE:
Phone beeps before dial tone
usually this means you have voicemail...listen to the messages and delete them and the beeps should go away...
Jul 20, 2010 | Uniden 2.4 GHz Cordless Phone System
How do I turn off the answering machine on my Uniden cordless phone/answerring machine model # EXA 915
To turn the Answering System off, press remote on the handset. The
talk/batt low LED lights green. The current Time and Day Stamp and
number of new messages recorded is announced on the Handset receiver.
Go here to get the complete manual:
http://www.retrevo.com/support/Uniden-EXA915-Telephones-manual/id/471dj482/t/2/
-DB
Aug 14, 2009 | Uniden Lands Phones
No dial tone beeps with fuzz disconnect battery to work
You may need to replace the battery, or let unit charge 12-18 hours without it being plugged into telephone jack-proper recharging method. You should have done this right away when it first came home.
Apr 28, 2009 | Uniden Cordless Phone
2 beeps, no dial tone
hand set no dail tone cant all out on the hand set due to no dail tone
Dec 05, 2008 | Uniden Cordless Phone
Setting the speed dial numbers.
When phone is on standby press memory-the talk led lite should flash. enter the phone # you want to store then push memeory again. Select the speed dial # you'd like to use for this phone # (0-9) then you should here a tone indicating it was successful. Let me know if this works for you-it should!!
Nov 12, 2008 | Uniden Cordless Phone
No dial tone when the talk button is pushed
the circut inside is acting up and will need repair, this can happen whenthe batterys are low in the phones and the base does not detect them , also the detect circut coud be bad , and or the automatic pick up circut for the answering machine
Oct 15, 2008 | Uniden 5.8GHz Expandable Cordless Phone...
Set the time
need to know how to set the time.
Oct 13, 2008 | Uniden Cordless Phone exai398i
No dial tone
the power supply of your phone is shorted,you need to coldsolder the components of your pcd.
Apr 05, 2008 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
104 people viewed this question
Top Uniden Lands Phones Experts
k24674
Marvin
Marvin
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
