Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune tl started giving ol code open lid
Maytag Neptune tl started giving ol code ..open lid and close would continue.. repair man put on a tub displacment sensor still ol code..removed agaitators found dime and small nail..worked one day then ol code ..now am getting uc code as well sometimes spins out wash cycle.. then get uc code on spin.. sometimes get it on wash cycle.. take clothes out.. will spin out water when uc code started opened lid and clothes would be bunched all on one side of the tub clutch pac and tub sensors were replaced 2/08 Machine purchased 1/06 HELP!!!!
  • 2 more comments
  • evelyn040133 Oct 23, 2009
    I am still getting the ol code on the wash cycle.....unpluged and plug back in washer went thru wash and rinse cycle....no code on spin cycle....but it sounded like it was trying to spin and stopped and tried again....took most of the load out and tried with just a few...no luck...took all out and tried spin only and it spins all the water out....When this first started it was not all the time, some days it would be fine others not...the repair man says no one knows how to work on them...Evelyn
  • evelyn040133 Oct 29, 2009
    Repair man was here....does not like to work on these machines.said get a new one....will put on a clutch for two hundred......watched the agaitators said not completing cycle......he took these off twice.......did not have uc dc code before.....ask if they could be on incorrectly..said no....arrows line up.....the clothes bunch up on one side of tub....is it possible he reversed them???....printed out a copy of the repair manual from on line..(said he did not have a manual)......took it laughed and said he give it to his boss....machine spins out on wash cycle.....how can it be the clutch....Thanks
  • evelyn040133 Nov 04, 2009
    Repair man either does not know or want to work on these machines.........My son found diagram in back of machine.....from your help and the gentleman that posted he lubricated the needle bearing and clutch he was able to get rid of the uc and dc codes.........ol still persists.......sometimes in the wash cycle.......yesterday it did not come up until the spin cycle was about to start.....ol says a binding on the agiators.....what can be binding????.......he removed the agiaters...cleaned....replaced right and left and matched arrows......when ol appears if you lift the lid and close it back it will finish the cycle????.......WHY??? We have also tried to unplug the machine to reset the codes...I really appreciate all the help you have gave us.....I just can not give up on a three year old $1,000.00 machine......Thanks for any suggestions you may have.......Evelyn
    No I am not getting uc anymore just OL.........
  • Maytag Master
  • 2,605 Answers
Hi, I think it is a faulty lid switch latch assembly. I have only ever had this one time in all my services experience...but it fixed the "ol" code and incomplete cycles problem. If someone has had a different result fine, but it worked in my case. Hope that helps...better late than never. Good Luck :)
Posted on Nov 05, 2009
    President:
  • 1,304 Answers
Most of your issues are with the clutch
this unit has had an issue with it since the very day theyu hit the market
the clutch is not allowing for the machine to spin back and forth without resistance thats why you get the uc code
the clutch sits at the bottom of the tub, and is wrapped by the belt
it can be replaced by a good handyman
the hard part is doing it with out rolling the tub over
the whole thing is held on by one 3/8 bolt in the middle
you can find your part readily availbable
at
www.appliancepartspros.com
just type in your model nuber and the search for the clutch
Posted on Nov 04, 2009
  • 2,841 Answers
The TL neptune has a small shock absorber on the middle left hand corner behind the front panel. it uses a small wiring clip that could be loose, with a type of inertia switch. A common issue with this machine is underloading. The snubber and springs allow a fair amount of movement. Don't do a few simple items or mixed load in this machine. The unbalance switch has been known to cause UC codes due to corrosion. I suggest taking the switch out...it'll look like a black strut on the front left hand side of the tub. Unclip the wiring harness and look at it for corrosion. Loss of electrical contact will cause this issue. If you see corrosion, spray a very small amount of wd 40 or preferably electrical cleaner on it, clean the metal pins inside the best you can, then apply an electrical grease to keep moisture out. As to the ol code is the washer level? You may need to replace the door switch or at least clean it with electrical cleaner.
Posted on Oct 29, 2009
  • NOT ME Oct 29, 2009
    It can be the clutch but check the others things I listed before replacing the clutch again.
  • 10,515 Answers
I assume that you are getting only UC code right now.Simple procedure to start with, unplug the washer for few minutes and let the control board reset all the programming, then plug in after few minutes.
Run the machine. If you are again getting UC code, If you are not getting any other code then i would suspect the tub position sensor(mount at back left side of tub).This error can also indicate a failed or failing clutch mechanism.
The sensors could fail at any time. That's the only SOLUTION to fix this.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 23, 2009
  • taran_2005
    taran_2005 Oct 24, 2009
    Thanks for your response!!
    oL flashes when the machine/motor control
    detects a load size that exceeds the
    washer's capacity OR basket can not
    disengage. This may signify:
    1. Load size exceeds washer capacity.
    Remove excess laundry, then restart cycle.
    2. Mechanical friction on drive mechanism,
    not allowing the basket to disengage.
    As this error is there even, when the clothes are not there.It sounds to be like a defective drive mechanism. That's the only reason when you would get both the codes.It seems mechanical friction on the motor.
    Now,
    You need to check, which part is causing this, There is a Diagnostic Test that would help. You could look at the same :-
    http://www.servicematters.com/docs/wirin...
    Hope i helped you.
  • taran_2005
    taran_2005 Oct 29, 2009
    Thanks!!
    No Comments. The solution i gave to you is what Maytag have suggested for this machine and as i said, it might be due to mechanical friction as it would not allow the basket to engage and would cause the issue.
    Thanks.
6ya staff
SOURCE:
Maytag neptune tl...shows op code but the lid is closed and locked and will not unlock.
my he maytag makes a squeaking noise and it wont fill up. could there be a sock stuck in there or something. and the lock wont lock.
Oct 26, 2013 | Maytag Neptune FAV6800AW Top Load Washer
I have an OP message on my Maytag washer FAV6800A/FAV9800A . The washer is not locked I can open the lead ...when I close the lid and start the washer the OP error comes up. Any help will be...
If you get no help at this forum Google This ""Neptune TL Washer FAV6800AWW""
5th post down you will find the SM and support for the "OP" error code. You have lost signaling thru the Left Hand Lid Lock............DH1200s
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
OD signal goes on w/ neptune washer w/ lid closed. Technician said it needed control latch assembly ($105) and control board($221). Plus labor ($155). Are these easy to get and replace? Is all this...
OD error code is associated with the Left Hand Lid Lock.
If you want to troubleshoot and repair yourself Google this""
That is a repair sticky where I have DIY support for FAV6800A or FAV9800A Maytag TL's.
You do not need a lot of mechanical experience just some guidance if you wan to save your 1$K machine.
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Code reads "OP" what does this mean?
Go here Neptune TL Washer FAV6800AWW
read the 7th post down ""issues related to the Left Hand Lid Lock for FAV6800A or FAV9800A machines.""
Mar 18, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytage Neptune TL gives od error code. Tried unplugging the machine. Tried many things, but nothing is working.
Could be loss of signaling thru the left hand Lid lock;
Google "Sticky Neptune TL Washer FAV6800AWW" for the Service Manual and support for troubleshooting the OD error code.
Mar 09, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
Mar 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Machine will not come on, the letter OP appears in the on window.
You have lost signaling from the Left Hand Lid lock.
The 1st easy test is with the lid open place a magnet over the Grey Bumper on the left side and see if the OP error code clears.
I can't find my post on this forum, nothing is indexed and the search function is terrible.
I don't want to put in a direct link to the washer repair forum of my choice so put in your browser this phrase; Sticky: Neptune TL Washer FAV6800AWW
This is a true DIY Appliance repair forum.
Feb 15, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune TL
The washer lid is open. The lid must be closed to start cycle. Close the lid and press Start/Pause.
Aug 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
90 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
