Frigidaire FRS26R4A Side by Side Refrigerator Logo
Anonymous Posted on Oct 23, 2009
Loud noise coming from icemaker...noise decreases when i increase temp and goes away when icemaker shut off. I set the initial temp at 3 degrees, then let it make ice - after about 3 hours it sounded like a cross between a jet and a harley... really loud noise that could be heard throughout the house. Shut ice maker off (lifted the wire) noise went down and after about 10 minutes stopped entirely. Bumped up temp to 6 degrees and tried again...noise came back after about 30 - 40 minutes but was less. This refrig has already been in once for SY FE or SY EF error - which tech said was a lose connection - Frig is brand new.
Anonymous
Level 2:
Novelist:
  • Expert 128 Answers
  • Posted on Oct 23, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
128
Questions
0
Helped
63362
Points
403
The icemaker is pretty simple, there is a motor, a solenoid, and a couple of switches.
It sounds like the whole icemaker mechanism is jammed or has a broken gear, and the motor is trying it's darndest to turn the stuck mechanism (grinding it's gears in the process), or the gear has already gone, and what's left of the gear is dancing around in there.
http://www.repairclinic.com/Appliance-Parts?s=t-frs26r4a-%3d%3dc248
My guess is either the $7 icemaker drive gear or the $94 icemaker assembly.
Testimonial: "Thanks - We'll see if that's the problem!"
True GDM-10 started making loud noise AFTER door was slammed after getting something inside; checked inside fan was running slow. Noise sound like something stuck in motor.
without knowing age of unit, I suggest replacing the motor. Sounds like the armature is worn the bearings and is moving inside the windings of the motor. I would do that first before moving forward with any other repairs.
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Loud ticking noise on driver side as speed hits 50mph gets louder as mph goes higher but noise gets quieter when mph goes down. If I do not reach 30-45 mph it will not tick, what is causing it
Noises are decieving. Cud be steering system or wheels or suspension. If ball joint fails car cud flip ovr.hav pro testdrive it. Seek a gudguy at surecritic.com
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
Whirlpool oven/ temp decreases when increase control is pressed
you need to replace the ( e o c ) the clock ) it's lost the ability to comprehend your needs .. the 350 start up is normal / but the up arrow should increase temp .. time should not be changing .. replace the clock / this part # 4452240 is n l a ) your clock can be sent in to be repaired / only . hope this info will help .. & 238.00 last price on this clock .
Dec 02, 2009 • Dishwashers
Our GTS22KBPWW refrigerator is making a very
How loud?, could be the icemaker. Does it make ice ok. try raising the ice tray bar to see if the noise goes away.
7helpful
6answers
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Oven cooks at 400 plus degrees when set at 350 degrees
If your problem is temperature do this;
Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
Then press "start" to end the calibration.
If you recently used self-cleaning you could have a thermal overload fuse problem.
Loud air intake engine noise on startup
I would guess it is the electronic fan clutch. It will cause the fan to run too fast (very loud) and the light will come on sometimes.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
