Freezer is working but power light on front panel is not on.
It sounds as if the bulb has burned out and you need to replace it. It might also be that, if the indicator light is located at the bottom of the cabinet, that it might have become unplugged from the wiring and it simply needs to be reconnected. In any case, be sure to unplug the freezer before you go removing anything, such as the access panel or the bulb mount, etc.
It is a very easy repair in most cases and you will need to determine the brand and model number for your freezer, since you didn't provide it here. Once you have that information, you can go to www.searspartsdirect.com and enter that info into the site and locate the replacement bulb for your freezer.
You'l be able to see a line drawing and a parts listing for all the various pieces for your freezer and can order it online directly from them, too, if you wish. You can also use the part number to get on from a local service provider if you prefer.
Remember, with more information (brand and a complete model #) we could provide you with the precise part numbers and a direct link to the web pages that show your specific freezer.
Hope you find this Very Helpful and best regards!
