When you have a low volt warning, it is simply because you have low volt. To confirm this use a multi-meter and check the voltage at:
A- the power connector for the GPS
B- the battery directly.
If A is bellow 10.5 V and B is above 11,x you have a cable problem (long or/and thin cable). If they are more or less the same, but bellow 10.5V you need to check your electric system.
