My HP PHOTOSMART M407 has a broken battery retainer door. Where can I buy a replacement door? Mail order, please?
SOURCE: HP Photosmart M407 Digicam
The issue is probably the button board on the camera. To open the camera, remove the six screws and pry open the camera from the bottom of the camera to remove the outer casing. Turn the camera so that the LCD is facing. Remove the aluminum frame around the LCD that holds the button board in place. Check the button board for mis-aligned or damaged discs (ie playback or view buttons) The discs are taped and may creep out of position. If they are out of position, push them back with the blunt edge of a screw-driver. If it looks fine, reassemble the camera.
SOURCE: Please let me know how I cAN ORDER the battery
Look in your owners manual and there should be a part section that gives the part numbers. After finding the part you can do a internet search on that part number, and it should bring it up.
SOURCE: HP M407 Broken LCD
You need to replace the LCD , honestly there is no one who can mend the glass. imagine a broken TFT screen for the laptop what can be done? i guess its nothing. I have two of these cameras one is working the one is faulty but still looking great for spares, why don't you get in touch?
SOURCE: were can i get manual for m407 photosmart
Everything is under Hp website. i did download all my stuff including firmware etc from hp.
