Have a Kenmore glass-top oven/stove that started sparking and smoking from the back and it blew the breakers. Model number is 790.99123405. Turned breakers back on and got F05 as an error code.
F05 has to do with the self cleaning mechanism. I know it goes with out saying, but sparks and smoke are a bad thing. i would strongly suggest turning off the breaker and calling in a service person.
Smoke means extreme heat or FIRE is melting something..
Please be safe and have it fixed..
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Check your main fuses, it sounds like you are only operating on 120 volts.One of them is blown.Or if on breakers, switch stove breaker off then on again.
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
