How to place a Motorola HS 850 bluetooth headset into paring mode:
You'll also need to enter the Lotus' bluetooth utility and have it search for bluetooth devices. If you set a password on the headset, you'll need to enter that password. If you didn't set a password and it asks for one, then the default is usually 0000 or 1234.
The next step would be to isolate the two devices to see which one is having the problem.
If you have another bluetooth headset or possibly another blue tooth enabled phone, try pairing either to your phone or your headset.
If both pair fine with other devices, then it's possible that there is some sort of hardware/software conflict between your devices that has occured since it was working properly.
To reset the Motorola HS820 Bluetooth headset, please connect the
accessory to the charger, leave the item connected for 5 seconds, and
then disconnect it. You need to repeat this operation 3 times.
hold the button with the boom closed and as soon as the light stops
blinking you realease the button and open the boom, the light should
remain on and steady. promt your cell phone to find it and the code is
0000
I believe you should be able to reset the headset by pressing the volume key and the power key pressing simultaneously for 5-10 seconds and it should erase the pair memory in the headset. Then repair again by using 0000 (4 zero's) as the passkey
I tried holding the buttons with the boom closed. That didn't work so I tried it with the boom open and the bluetooth deviced beeped. But, it still searches and doesn't find anything.
My LG Lotus says that it is paired, but if I put on the bluetooth, it doesn't work.
This is an HS850, not an 820, but I have tried your solution 4 times and my phone does not find the device. I have let the bluetooth drain, recharged and tried also - to no avail.
I have a Motorola HS850 bluetooth headset that I set up with no problem about 2 months ago when I changed to a LG Lotus cell phone. For that past few weeks, the Motorola doesn't connect with my phone. I have had suggestions from your site as to how to rest the Motorola, but after doing the things suggested, it still doesn't pair with the LG Lotus. The LG Lotus seems to be set up OK.
I have let the Motorola run down its power to reset it, to no avail.
I have done all these things.
