Microsoft Excel for PC Logo
Posted on Oct 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41 Determine the following: a) Highest value observed b) Lowest value observed c) Standard deviation from the ungroup data d) Frequency e) Mean and Standard deviation from group data.
Craig Layne
Level 2:
  • Expert 101 Answers
  • Posted on Oct 23, 2009
Craig Layne
Expert
Level 2:
Answers
101
Questions
Helped
32195
Points
309
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
I have a Precor 9.45 I that states error 10 what is wrong with it
Precor Error 10, Line Frequency out of Acceptable Range Probable Cause 1. Treadmill is connected to a non-dedicated AC circuit
2. The AC hot and AC neutral wires are reversed on a 120VAC circuit.
3. The upper PCA has an incorrect jumper setting.
4. Fuse feeding the stepdown transformer is bad.
5. AC line frequency is incorrect.
6. AC line may be excessively noisy. Corrective Action
  1. Treadmill must be connected to a completely dedicated 20amp AC circuit. Both hot and neutral leads must be dedicated to the treadmill. If the circuit is shared with another piece of equipment, it can cause enough electrical noise to make the AC line frequency impossible to identify. The AC circuit for the treadmill must be re-configured as a completely dedicated 20amp circuit.
  2. Many line frequency detection systems observe the AC line frequency on the hot AC line. In the event of a reversed 120VAC circuit, the observation is taking place on the neutral (ground) part of the AC line. Many observing systems are not capable of detecting line frequency on the neutral line. First it must be determined if the reversal is in the AC wiring feeding the treadmill or in the internal wiring of the treadmill. The hot and neutral lines can be confirmed by measuring each in reference to AC (green wire) ground. The hot wire will read full line voltage (commonly 105 - 120VAC) and the neutral should read about 0VAC.
  3. The upper PCA's for some units had a jumper setting for use with SCR or PWM drive circuits. If the jumper was set on the upper PCA as PWM on an SCR unit, the Error 10 appears. Change the jumper setting to SCR to correct the problem.
  4. A pair of fuses were used on some treadmills (C944 PWM version 2 and C96x PWM version 2) that fed the stepdown transformer for the low voltage power supply on the lower PCA. The AC line frequency was observed on the output of one of the fuses. If the fuse blew, AC line frequency could not be detected even though the treadmill appeared normal under other circumstances.
  5. It is unlikely, however, the AC line frequency could be out of acceptable limits. This would more likely occor in countries were AC power systems may not be well developed and controlled. There is little that can be done to correct this issue. If the source frequency cannot be corrected, the only possibility would be replacing the treadmill with one that utilizes a PWM motor controller. PWM motor controllers do not depend on line frequency for speed control.
  6. At times the AC being fed into the distribution system is too electrically noisy to allow correct line frequency identification. This can be caused by other equipment within the AC distribution system creating the electrical noise. It can be difficult to identify the source of the electrical noise. There is little that can be done to correct this issue. The source needs to be located and removed or made electrically quiet. If this cannot be done, the only possibility would be replacing the treadmill with one that utilizes a PWM motor controller. PWM motor controllers do not depend on line frequency for speed control.
Precor Error Code 10 10 Line Frequency out of Acceptable Range
tip
MOTOROLA TIPS
Motorola Secret Codes
IMEI number:
*#06#
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work
on Sep 27, 2010 • Cell Phones
tip
Motorola secret tips
Enable EFR:
Function :
Change pin:
then you will enter the secret engineering menu under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
on Mar 08, 2010 • Cell Phones
1helpful
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
Thanks for using fixya .
1helpful
My motorola v360 unlock code and security code has been changed and now i cont entre my phone please help?
hello,
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
4helpful
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Lowering email polling frequency
It cannot be lowered cos that is the preset lowest obtainable.
Get used to it.
Cheers.
Rate this.
Unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
