Question about RCA F32650 32" TV
TV does not turn on. When plugged into an outlet makes a high pitch noise.
Our RCA F32650 32in tv does not turn on. When plugged into an outlet makes a high pitch chirping noise. Happened over night when I believe we had a electrical surge to the tv but not sure. Initially the tv would just not turn on. After a few tries their was a constant chirping noise with it plugged into an outlet.
I do not have the skill set to fix this tv but my wife's grandpa has tinkered with small appliances including tvs. Could this be an easy fix for him? If so what parts are needed, at what cost, and where can I find parts for this tv? If this is a more complex fix, what would it cost to have it fixed by a professional? Also, is there a reset button for this tv?
Thanks. in advance for your help.
  • Anonymous Feb 08, 2008
    the television just cut out after turning on.aia pressed the clear button onthe remote and then the channel up button then the tv just shut down,I tried turning it on but the power button just kept on blinking
  • 373 Answers
Your problem is a shorted horizontal output transistor C5148 located behind the highvoltage transformer on a heat sink with a clip over it and you can't see the number unless you remove the clip Has to be unsolded and solder in new. Also the highvoltage transformer must be replaced This is the big part with the large red wire coming out and going to the top of the picture tube. Must be unsoldered and replaced with original RCA .....do not get a replacement It has several connections plus three wires to connect to it and I recommend using desoldering brad can get at Radio Shack 5 foot roll. Well as you can see it gets pretty involved. You can't get the parts from most distributors unless you have a business. If he tackles it and has a distributor the parts would run about $50 to $60 and a repairman average should be less than $200 and more than $150 hope this helps. Contact me for any questions you may have. I am more than willing to help.
Posted on Dec 30, 2007
SOURCE:
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Dec 13, 2015 | Televison & Video
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
Y rca 27f500tdv tv high pitched noise
Change the horizontal IC are damaged
Jul 28, 2009 | Televison & Video
When my rca 36F530 tv is plugged in it makes a high pitched buzzing noise picture does not come on
There is a short circuit in the high voltage circuit. the transformer who helps to create the high voltage or his power transistor is damage. replacement needed. the repair is not expensive, because the parts are average repair. Ask for an estimate.
May 01, 2009 | RCA 36F530T 36" TV
Trouble turning on tv. High pitched noise/click.
The mainboard might have some loose components, or cold solder , or may be the filter capacitors are becoming faulty. Yes it is worth repairing, bring it to the repair shop. Cheers.
Nov 25, 2008 | RCA Televison & Video
High Pitched Ticking Noise
Horizontal output transistor is shorted,caused by bad flyback
transformer.If you want to pursue the repair,please give the
service number off back......I will get part # s........T.
Oct 25, 2007 | RCA F36705 36" TV
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Sep 12, 2006 | RCA F25649 25" TV
RCA F32650 32" TV Logo
161 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
