Nordic Track NordicTrack Treadmill, A2550 Logo
Posted on Oct 23, 2009
I have a nordic track a2350,and the incline wont stay up.It beeps every 10 seconds and goes up then down .any tips
  • Anonymous Mar 12, 2014
    It will work great for awhile than out of the blue will do this continuous beeping and nothing works. I try turning off and on and tried reseting it but it won't so anything but beep.
  • Anonymous Mar 26, 2014
    Belt replacement
Anonymous
Level 1:
  • Contributor 40 Answers
  • Posted on Oct 25, 2009
Anonymous
Contributor
Level 1:
Answers
40
Questions
0
Helped
34907
Points
84
I've seen this problem several times, but many things can cause it. It's most likely the motor control board, but it could be a number of things. I'd have it looked at.
1helpful
I have a Nordic Track A2350 treadmill and the display is blank. Anyone fix this yet?
If you wish to get some details; check the site linked here. Pull up older posts Nordic. Surf the site with patience.
http://electro-medical.blogspot.com/
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Incline goes reverse on my nordic track treadmill incline goes reverse on my nordic track treadmill
The red and black wires going from the control board to your incline motor are reversed.
Nordik track A2350 can't fit through door
see the video and proceed according.
God bless you
1helpful
On my nordictrack a/2350 the incline stoped working what could be wrong?
Follow the instructions found in your manual for incline calibration first. With the safety key/magnet in, press incline up, remove the key while the numbers are changing, release the incline button then reinstall the safety key. The incline should calibrate.
If the motor moves, then stops b4 completing it's cycle, the incline sensor may be defective. The sensor is the black cap/wire coming out of the top of the motor. Make sure it is connected properly.
If the sensor is defective, you have to order the complete motor to repair the problem The sensor can be replaced without replacing the motor, but it is not available as a replacement part..
Part #249516 around $110....
1helpful
How do i raise nordic track treadmill?
if that is where it catches then that is how far it goes there is no adjustments. Make sure the incline is the whole way down
6helpful
2answers
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
I have a nordic track a2350 and the belt stopped working, the incline works and the top part lights up. What do i need to do?
This is usually related to the control pwb which is located under the motor "hood".
You can get this part from iconservice.com by going to the replacement parts section of the site and entering the model number of your machine, Which is located on the lower frame assembly below the walk belt. After you have receieved the part you can follow this procedure to repair it.
http://www.fixya.com/support/t3807308-belt_goes_full_speed_when_started_shuts
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
