Was the error code F01?
If it is ther error code means EEPROM ERROR
A communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU occurred. and or
PUMP DRIVE ERROR
The pump driver fails to activate.
and or
MAIN RELAYS ERROR
One of the main relays is not working properly.
Could be cause by a power glitch. unplug unit wait 10 seconds and plug unit back in. If code returns replace Central Control Unit (CCU)
Error code (du)
SOURCE: F1 error code on cabrio washer
The F51 code is also covered as long as its the circuit board that is failing. The F51 code is a general code that covers a few other problems.
