Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
My glowbouy flashes green and red...what does this mean
  • 640 Answers
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Posted on Jun 16, 2010
SOURCE:
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
GlowBouy not lighting up, no matter how long charged
Most of the time, that is going to indicate a problem with the battery no matter what type of swimming pool lights you have, but you are in luck, because I have located a copy of the owners manual for this light. Hope this helps!
http://www.spawarehouse.com/IG/OwnersManual/PoolLight-gb_inst_manual.pdf
Jul 06, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
The intercom light on my GE 2-9451 phone is flashing between green and red
This is what is in the user manual about the ligth means
Red Someone else is using the line.
Flashing red fast Incoming call.
Green You’re using the line.
Flashing green Line on hold.
Flashing red Line on hold by other stations.
Flashing yellow Incoming call transfer
Dec 18, 2009 | Video Game Consoles & Games
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Will not flash red/green
This means Battery is low to charge the capacitor.
I suggest you test this with unused new Duracell.
Oct 06, 2008 | Vivitar 285HV Flash
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
1,574 people viewed this question
Top NRS Pool & Spa Experts
Bath and Spa Parts...
US Parts Center
US Parts Center
Tom Chichester
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
