Frigidaire Affinity ATF7000EG Logo
Posted on Dec 30, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer stuck on Pause mode
My washer is stuck on the pause mode. I can't reset the computer. I have unpluged it. I have hit cance, pause etc. It is a model where all the led lights blinks 3 times after I try to cancel or restart it. It is affinity ATF7000ESO
  • 4 more comments
  • Valari1 Dec 30, 2007
    i'll try i tand let you know? I will need to wait for my husband to get home after jan 1 as I don't know where the pressure sensor is.
    Thanks
  • Valari1 Jan 01, 2008
    I have opened the top panel but I cannot recognize the pressure any other this to let me know what I'm looking at
    Thanks
    Thans soooooo much. it worked . i just unpluged both things that could have been what you were describing. and it reset
  • Anonymous May 06, 2008
    OMG..... I looked all over to find a solution to the same problem you had. Who needs technicians anymore? Thanks for the answer to my problem! IT WORKED!
  • Anonymous May 19, 2008
    WASHER STUCK ON PAU 50. 3 BEEPS WHEN START BUTTON IS
    PRESSED ERR MESSAGE AND MACHINE WILL NOT START
  • Anonymous Mar 25, 2014
    front load washing machine is in pause mode
Anonymous
Level 3:
President:
  • Master 1,314 Answers
  • Posted on Dec 30, 2007
Anonymous
Master
Level 3:
President:
Answers
1314
Questions
6
Helped
897493
Points
3823
Remove the washer from the electrical supply.
2. Remove the top panel and disconnect the wire plug to the pressure sensor.
3. Reconnect the washer to the electrical supply.
4. Press start and wait 10 seconds (washer will drop out of the continuous loop).
5. Remove the washer from the electrical supply.
6. Reconnect wire plug to pressure sensor and reinstall the top panel.
7. Reconnect the washer to the electrical supply and verify proper functionality.
8. If same symptoms occur, install a new console control.
  • Anonymous Dec 30, 2007
    The pressure sensor is under the main top panel it well have a clear see thur hose on it. You can do this my wife is as good as i am she fixes alot of them. The sensor will either be gold or white plastic most always. Look for the screws on the back of the top panel, then remove them. Push the panel back lift it up and then follow directions. Go get'em girl you can do this reply if you need me thanks
  • Anonymous Jan 01, 2008
    ata girl knew you could do it i was just getting ready to send you a message with a picture from the svc manuel way to go yaaaaaaa
A
Anonymous
Thank You very much . I unpluged the sensor and did as you said and than I was able to get into the codes. Again thanks
A
Anonymous
Thank you so very much this was the solution to my problem. You saved us at least $200.00 and wailing and nashing of teeth
Washers start button will only flash as in pause in stead start washing ? I unplugged wash to reset computer and still flashing in pause mode ? What's the next step in troubleshooting thanks nicole k in...
You need to get the diagnostic info. It should be located just inside the kickplate. Unplug the washer, and then remove the kickplate. Inside will be a packet of info that will help you diagnose your washing machine.
My neptune washer is stuck in pause mode I can't set it any any wash mode to wash a load the start/pause light just keeps blinking. Is there any way to reset it or boot it to get it started again thanks...
Karen,
Power it down by pulling the 120VAC power cord to the washer then plug back in and see if it will progress with the wash cycle. Which machine do you own the FAV6800A LED console display or the FAB9800A LCD console.
If still no good I will have you try to get into Service Mode but let’s see if a power cycle will clear the issue…….Rich
You will need the Service Manual for reference. Sears Parts Direct for reference.
The washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
6helpful
Canceled the clean washer cycle, got "INT", won't work now
Unplug machine, wait 2 minutes and re-plug. This should reset computer and unlock door.
2answers
Pause mode stuck
Is the door firmly closed? Open the door and close it firmly. If the pause button is really stuck, you will need to repair/replace the board.
2helpful
3answers
Paused. now stuck. cannot open, turn off, etc.
Unpluggin the machine is pretty much the only way to reset it.Leave it unplugged for a couple hours if that doesnt work its most like a control board issue
32helpful
8answers
Frigidaire Front Loading Washer, ATF6000ES stuck on pause mode - HELP!
I fixed this myself and it only took about 5 minutes. The problem is the door latch needs to be reset, which requires unplugging it's three electrical connections. This has to be done inside the washer outer seal, but it is easy to get to. First remove the outer ring that holds the seal on. Next remove only the side of the seal closest to the door latch (again only the outer seal needs to be undone). With this done remove the two screws holding the door latch in place (inside). Remove the latch, unplug the three connectors, plug them back in then reassemble everything. When all is back in place hit "cancel" and it should be good to go.
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
