Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have a used bizhub which I paid to set up on my
I have a used bizhubc350 which I paid to set up on my network. I moved it to another location and now I cannot install it to a switch and 1 computer. The printer icon is gone but he firey is still installed
    New Friend:
  • 44 Answers
Print out a config page from the fiery. Find the IP address and put that in your web browser. Click on WebTools and the download tab and download the drivers. Install the PCL or PS driver
Posted on Nov 29, 2009
  • Konica Minolta Expert
  • 158 Answers
Install the driver as a local printer then go to the properties of the driver and click on the ports tab and click on add port click on standard tcpip and then new port enter the tcpip address click on lpr and enable byte counting and the print queue name is print click ok and apply it should print after that
Posted on Oct 23, 2009
6ya staff
SOURCE:
What can do to configure my bizhub c300when network setting did not display?
Go to Admin mode, then network, TCP/IP, then enter the IP address, subnet and gateway. SET FOR STATIC IP not DHCP!!!!!!!
Default admin pw 12345678
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 13, 2015 | Konica Minolta Bizhub C300 All-In-One...
Bizhub doesn't recognize new IP address
We had the same issue when we moved two years ago. We cleared the settings (write them down first) shut the machines down, bother printer and server. Then reentered the settings, saved by shutting them off again, then restarted the server first, then the printer. That seemed to do the trick. Good Luck
May 07, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
I have konica bizhub c252 the machine have network card but in the utility mode setup I not can see network setup for may change
u must be in administrator settings, pwd 12345678 then you'll have the network settings. if not, a technician msut pass to downlaod a new firmware/ use the "s-tool" tool to erase smoe abd informations on your network card.
Jan 15, 2011 | Konica Minolta bizhub C250 All-In-One...
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Printing through Wireless network
some wireless routers do not allow printing or file sharing check your router specs and settings. also if the wireless router has encryption turned on the bizhub will not print thru the router because the bizhub cannot be set to use a ssid and key code to access the router
Nov 07, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Missing network tab on konica minolta c250
1st try restarting the Bizhub. Use the switch located behind the front panel, not the switch to the right of the operation panel.
If that is unsuccessful, try setting the Bizhub to DHCP (use the administrator mode under utility/counter at the machine), then back to a fixed IP.
Aug 05, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
We recently moved to a new building. Our Konica
Call Konica support and they can guide you through the process. Depends to some extent on your network connection, i.e. ethernet or usb.
Using the keypad on the printer, you will have to establish an ip address on the printer so the computer can find it and the printer can find the computer. There are several ways to set it up, however.
This is also outlined in the cd-rom users guide.
But once you have your network connected and the computer network is set up for print and file sharing, get a Bizhub support tech on the line and he'll walk you through it in 5 minutes.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 24, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
BizHub 350 Network Fax - Prints instead of faxing
Set the Gateway TX to "Allow"
1. Press the Utility/Counter button.
2. Touch Admin Management
3. Enter Password (The default password is 12345678)
4. Touch Admin2
5. Touch Network Settings
6. Touch Network Settings1
7. Touch Scanner Settings
8. Touch Gateway TX
9. Set Gateway TX to Allow
Dec 23, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Can not make bizhub c252 scanning trough e-mail feature
with scan to Email on this machine you need a mail server that is local with ftp scanning you need IIS running on either XP Pro or server OS SMB Scanning can be done but only if you are using an eithernet connection which one of these do you want do to do
Sep 20, 2007 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
156 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
