Televison & Video Logo
Posted on Dec 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi Rear Projection LCD TV Lamp
Ls it worth replacing lcd lamp every year or should l  buy a new TV ? It's a 50 in Hitachi LCD  Rear Projection TV
We have blue along the left side and corners also on the right side asplotch of light yellow approx 10''long. Any advice ????? Tryed resets from manual none worked
  • 1 more comment
  • rtromero Feb 07, 2008
    Yes, I have the same problem. Mine is at the right top corner about the size of a palm
  • Anonymous Feb 18, 2008
    picture is too dark
  • Anonymous Mar 30, 2009
    Do you have to replace the lamp every year?
Demonic-2011
Level 3:
  • Televison & ... Master 513 Answers
  • Posted on Dec 20, 2017
Demonic-2011
Level 3:
Answers
513
Questions
0
Helped
212181
Points
1606
Depends on whether you use the TV as your "daily driver" or not. Colour patches on the edges of the screen sounds a bit like a purity problem. If replacing the lamp every year is proving too expensive, not to mention a tad repetitive since it indicates the short life of the lamp(s), plus the set happens to be a few years old, perhaps consider a new TV of approximately the same screen size (50" and up) - if the latter is what you want to do.
5 Related Answers
Anonymous
  • 398 Answers
  • Posted on Jul 24, 2007
SOURCE: hitachi 50 rear projection
Just curious... since the Hitachi 50UX57B projection TV does not have any lamps in it, exactly which "lamp" did you replace? Did you actually replace the entire blue CRT itself?
Anonymous
  • 1284 Answers
  • Posted on Nov 30, 2007
SOURCE: Sony Bravia LCD T.V.
It is most likely a fan (there are 2 to 3 of them in the set) that is making the noise. I doubt seriously that the lamp is causing a buzzing noise. The only other buzzing sound can come from the ballast wich powers the lamp.
Anonymous
  • 579 Answers
  • Posted on Dec 31, 2007
SOURCE: Hitachi Rear Projection LCD TV Lamp
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Anonymous
  • 18 Answers
  • Posted on Jan 05, 2008
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Anonymous
  • Posted on Jul 17, 2008
SOURCE: Hitachi 50VF820 (LCD projection)randomly turns
I believe I may have solved this problem by putting a small fan blowing on the intake of the Lamp fan. I put the fan in place and the TV has not turned off randomly since. That was only a day ago so I'll see if it is a permanent fix. If so I will probably try to mount the fan on the back of the TV out of sight.
Hitachi LCD M50VS810 -- picture gradually darkened up over the past 4 days and now picture won't come on. Replace bulb?
If it uses a lamp that is possible---sets with a lamp will often dim down just before the lamp fails in a total way.
I have a Sony Grand WEGA KDF-50WE655 50-Inch LCD Projection TV and when I turn it on the screen stays black and the green light flashes for 20-30sec then the TV turns itself off and 2 red solid lights...
The tv projection Lamp inside the tv now has it been inside this tv like 1 1/2 or 2 years already and tv is on and used it like 4 or 5 hours every days?Yes,the tv now the 2 red LEDS solid lights apear.One of those light have a word "Lamp" written on it bazel frame?Yes,100% ur tv projection Lamp life are over and ending.Tries websites like Ebay.com,Partstore.com to buy a new tv projection Lamp for the replacement.
6helpful
I have a sony xbr lcd projection tv . it goes on and off all the time . like every two min . and the standby light comes on. model KF-50XBR800
Its symptom of weak lamp that reaches to end of its working hours life span. If lamp has not been replaced in last 2-3 years then replace it to fix tv problem.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
1helpful
2answers
PT50LC14 Color problem with color too much yellow and green no white or blues can not correct is this the lamp again im on why does it seem that I end up replacing the lamp every year (on number 3 now)....
ok,,your problem is not on the lamp itself.,the problem is on your screen controller.the controller is connected on the plyback you can adjust the screen intensity of the red,green,blue cathode..on your screen adjustment.
I have a question, We bought our Hatchi 50 inch tv 3 years ago
The manufacturer normally doesn't count the lamp for the warranty, but call them definitely worth checking w/ the manufacturer. Otherwise if you need to buy a lamp you can try Discount-Merchant.com they have FREE trouble shooting available so you can check to make sure it is the lamp.
TV turns on but produces no visual or audio. Screen just stays black
Your lamp is burned out . I have a 52" hitachi lcd as well, and i have hadd to replace the lamp once a year. its a mercury based bulb which emulates alot of heat and if your exhaust fans are not working properly it will cuase it to fail or burn out more frequently than it should. cost is @ $120.00 for replacement bulb
Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
1helpful
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
