Question about Yamaha HTR-6130 Receiver
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
PS3 Blu-Ray connected to Sony Bravia TV with HDMT cable. DTVHD receiver connected to TV with HDMI cable and audio optical cable from DTVHD receiver to Yamaha HTR-640 optical input (DTV/CB). Optical cable from PS3 output to Yamaha 640 optical input (CD). Surround sound from DTV works fine, but no sound when I play a blu-ray DVD on the PS3.
  • 4 more comments
  • Anonymous Feb 05, 2008
    Hey!! I'm having the EXACT same issue!! Except I'm using a Yamaha HTR-6030... and getting no sound out of the receiver. My DTV receiver works wonderfully through the AV receiver... have you figured out the problem?
  • avenger77
    avenger77 Aug 09, 2008
    We have a Yamaha HTR-6040 AV Receiver wih the PS3 and it worked fine using optical audio for 2 months, then just stopped working today. Currently investigating.
  • jlewis_3 Mar 05, 2009
    having same issue with htr-6130 . using hdmi on DTV and optical and works fine. using HDMI from PS3 and optical to reciever and just get regular sound and video(1080i) NO SPEAKERS! This is with HDMI to the tv also. Tried switching one for the other still no SPEAKERS! What gives ? It's probably something stupid........Any ideas?
  • Shane Martin May 11, 2010
    Do you have CD selected as the source on the receiver ?
  • Anonymous Mar 15, 2014
    the soundbar I have purchased only has optical connectivity and my Sony TV hasn't cot that. How do I connect the soundbar? I also don't have wireless.
  • Anonymous Mar 17, 2014
    cannot see the picture on TV monitor and can hear only audio
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Yamaha Master
  • 1,001 Answers
  • Excellent Bluetooth Receiver,stable connectivity and remarkable signal stability.
  • Smooth call conversation and non-stop and clear music streaming creates enjoyable listening experience.
Amazon com Charm sonic Wireless Portable Bluetooth 4 1 Receiver Wireless...
Posted on Jan 17, 2017
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Posted on Jan 11, 2008
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE:
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
I'm connecting a yamaha receiver6160 to my sony bravia with a hmi cable from the out of the receiver to yhe hmi 1 on tv how do i get the sound from my tv through my receiver and which input should i use
The audio comes from the source , and from the source you may need
to connect an audio cable that connects to the TV, only if your having
difficulty with each audio settings.
May 21, 2010 | Yamaha HTR-6160 Receiver
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Mar 15, 2009 | Yamaha HTR-6130 Receiver
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
Muffled sound from rear speakers why watching TV
switch the HDMI cables around to make sure its not one of them, if the problem is one of them it will move with the cable,if no change i would suspect the coaxial cable next.
Feb 12, 2009 | Onkyo TX-SR506 Receiver
How to hook up everything!
I have similar equipment.
You should use an audio digital cable to connect the bluray to the Yamaha receiver and another digital audio cable to connect the HD box to the Yamaha receiver.
Hope this helps.
Dec 23, 2008 | Yamaha HTR-5650 Receiver
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
Nov 28, 2008 | Audio Players & Recorders
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
Yamaha HTR-6130 Receiver Logo
3,655 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
