Toshiba 24AF42 24" TV Logo
Posted on Oct 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not the input. Is there a way to access the menu or change the input from the TV its self? There is no menu or input button on the TV.
Chi Chu
Level 3:
  • Toshiba Master 8,457 Answers
  • Posted on Oct 22, 2009
Chi Chu
Toshiba Master
Level 3:
Answers
8457
Questions
0
Helped
2822626
Points
26282
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
I have a toshiba tv without a remote and I'm trying to set up my magnavox to the tv without a remote and can't figure it out.
Buy a universal remote control and program it to work with the television and DVD player you have.
1helpful
I need the tv remote codes for my toshiba tv model #24AF42. Lost the remote and need to use my Time Warner cable remote. Thanks
0028,0025,0029,0021. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
I have a toshiba md20fmir tv/dvd and a toshiba dc-sb2 remote, can i make them work together and how do i do it, please help
Do you mean the MD20FM1R TV/DVD? The DC-SB2 isn't the correct remote for this TV/DVD. You would need to recode the internal chip. The MD20M1R uses the DC-FL20S remote. A substitute remote is available here: http://www.toshiba.newremotecontrol.com/catalog_item.php?catnum=BZ614254 . Alternatively, a universal remote that was programmed at least 6 months after the MD20M1R was released will probably have the correct codes for your TV.
I wish that I had better news for you.
No audio on on my toshiba 24af42 when I play my dvd player
that would be a fault with the cable. If your using a SCART connection then try moving &pushing both ends, the sound might come back orherwise you need a new cable. if your using HDMI then try unplugging the cable at both ends & then plug it back in, that normally works.
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
2answers
How can I use the input on my toshiba TV without a remote?
You can change your inputs by pressing the menu button on the panel of your television.
2helpful
2answers
1helpful
3answers
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
