You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Change the motor is on bad conditions
