GE profile gas range
Hello zjaffri
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, when I press start button after selecting bake, circuit breaker gets out.
this means there is a short circuit some where in your range! If you are not able to find and repair it your self ,you may need service to diagnose this!
Please do not for get to give a rating before you sign off!
Here is an interesting report I just read!
Repair or replace?
When to pull the plug on your old range
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your range,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your range is under warranty or less than four years old ,
paying for a repair makes sense.
Note that ranges under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your ranger is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new range.
Data also shows that it doesn't pay to fix a less-expensive range
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of ranges you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Thank You, HUUUM
Repair or replace?
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
