This model number is not coming up. The 'J' on the end, is that a typo? There is no model with the 'J' on the end that I can find.
If your model is GE GSS20GEW, then the spec sheet indicates there is no water filtration system on this refrigerator. Although the manufacturer's generic blurb on it says "...fresh, filtered water...".
Here is the link to the specifications:
http://www.rainbowappliance.com/GSS20GEWBB.html#
If you're sure it has a filtration system and there is not an obvious canister shaped filter inside the cabinet then they are usually located underneath the unit on the front. There will be a round looking thing protruding from the bottom-front grill or the grill will have to be snapped out to get to the filter. I would look here for it.
If this information was useful, please select YES to the first to rating questios. Good Luck and thank you!
