Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Did you try turning off the power and then connecting it again?
If still problem is there open the door.
Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry.
Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on.
with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Hi, Thanks for writing to Fixya.com. Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again Thanks for contacting Fixya and please accept the solution if it has helped you.
you need to pull the dishwasher out and check your heating element. to remove code hit heated dry and normal wash and toggle till all the lights light up and then hit cancel this should clear your code. there is a problem with the heater or the heater curcuit let me know how it goes
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
