Sony HVR-Z1U Mini DV Camcorder Logo
Posted on Oct 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to record from my computer back to "tape" on my Sony Z1U. Everything is fine on the computer side, but nothing happens when I hit "record" on my camera - please help
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Oct 21, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737612
Points
36075
If you are using the rca jacks, they are only outputs and you cannot record in. Unless this is a special camera. Let me know and I can find some info
Sony HDV Z1U C:31:23 will not load tape cartridge
Tape may be jammed. Try to move tape with pencil eraser
like with the old cassettes.
2answers
Sony TC-WR670 how to copy my old cassettes to new tape on bay B?
I can't fing my manuals either. I have the same one. I think you put the originalin one side and the blank in the other. Rewind both to starting point. Press play and pause on original. Press the red record button on the copy tape. Then press pause and press the high speed dub button. If nothing happens hit the pause button on each side. Just trying to remember. May not be right.
2helpful
Hi. put in a mini-dv tape recorded on a sony z1 camera, the sony dsr-45p tape deck doesn't show any footage from the tape despite the camera had playback to show that footage was recorded. Using a windows...
the issue is probably related to the format the tape was recorded in. a z1u records in hi def (hdv) the dsr 45 is standard def ntsc. not compatable, play the tape in a z1 to recover
I can record on one side only, if I try to record on
It's a 4-channel recorder. That's four recorded channels in the same direction. You COULD use it like a standard 2-channel stereo recorder with bi-directional playback if you recorded only the front tracks. THAT would produce a 1/4-track stereo tape with two sides (directions).
In the photo, the front and back are clearly marked.
http://www.thevintageknob.org/SONY/sonyvault/TC7884/TC7884.html
Leave the Back Record switches in PB mode.
2answers
Recording and Playback error
I'm not sure what the solution is, but I am having the same probelms, and I would appreciate any help with this since I am shooting a childrens camp and I am fairly isolated and don't have the time to swop cameras or send it to get fixed. I need to know if the recording is fine (video and audio) but the playback is not working correctly...or is it not recording correctly or playing back correctly. The sound cuts out from time to time in playback. Thank you.
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Everything seems fine, but will not record.
buy a cleaning cassette and play three times and then try to record .
2answers
Code 31 22 t reel error
Look i first hit reset for a second and it work for a second. Then it went back to the same problem. I turned the camcorder back on and i held the reset but while it was on. I held the reset button for like a minute, then every thing worked we recorded, the tape ejected fine, we watched what we had recorded and kept on testing it and everything still works give this a shot.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
