Ovens Logo
Posted on Oct 21, 2009
How do I fit a Flame Failure Device into a Mistral EL
How do I fit a Flame Failure Device into a Mistral EL Leisure LPG oven.The cooker is about 18 years old and works perfectly. However the FFD has gone, I have a new one, correct for the model but wondered if anyone could tell me, step by step, how to put in the new one.
Anonymous
Level 1:
  • Contributor 12 Answers
  • Posted on Oct 24, 2009
Anonymous
Contributor
Level 1:
Answers
12
Questions
0
Helped
55172
Points
63
You should not attempt to repair this unless you are gas registered. It is against the law!
2helpful
Instructions for lighting grill for Leisure Cooker GR6GV MKII
Have your flame next to the pilot light before turning on. Hold pilot knob in while lighting. Hold it in for about 30 seconds once it is lit. Then you can turn it to the on position and set the temp.
Feb 24, 2013 • Ovens
2helpful
Canon Carrick LPG cooker-failure of full flame control bottom oven I have had this cooker for 14 months and used it for 6 months only from new. The bottom main oven has just started to play...
I had the same problem. I solved it by re-attaching a device which had come undone. On the right hand side of the burner is a rod with a metal wire attached. This was lying loose. It should be fixed to a little grey clip which is itself attached to a a piece of metal. By re-fixing the clip and the rod to the clip it solved the problem. Hope this helps. I have photos of how it should look. email [email protected] for a JPG.
Dec 01, 2010 • Ovens
I need an lpg conversion manual for a Bush AG56SW gas cooker
i need a LPG conversion manual for a Bush AG56SW
Nov 15, 2010 • Ovens
28helpful
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 • Ovens
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 • Ovens
2helpful
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 • Ovens
2helpful
Creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Apr 06, 2010 • Ovens
I can't get a low flame on my lpg hob. The flame isn't outrageously huge so I think the hob is converted for lpg. But I can never get anything on a simmer, even with simmer mats over the flames. ...
If you remove control knobs you should find a hole where screwdriver can be inserted to adjust the flame failing this ensure correct injectors were installed when converted to lpg
Jul 13, 2009 • Ovens
9helpful
6answers
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
