F21 = LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
Press PAUSE/CANCEL two times to clear the display.
If you had this washer for sometime the most likely cause is Item 4. If so remove the lower front panel place a pan under the white filter (before the pump)
remove the filter and clean and remove any foreign material and reinstall filter.
else
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump
is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
