To reset the battery you need to locate the "AC" inside your watch. The AC terminal is a little metal spot (usually a circle and usually gold colored) on the inside of your watch. Looking at the inside of your watch the "AC" should be labeled, though it may take a magnifier to identify it.
It may be labeled simply "AC" or it may have an arrow pointing to it. Once you locate it use a pair of tweezer or a paper clip and touch the battery and the AC together for a few seconds and release; you may have to do this twice. This will reset your watch an give you the ability to correctly wet your watch.
Do you mean reset after new battery install? If this is the case, you need to use a pair of tweezers putting one end on the battery and the other end on a little spot (usually gold colored) labeled "AC" on the inside of your watch. Hold these two together for a few seconds, release and repeat.
