Question about True 72 cu. ft. / 2039 liter Commercial Freezer T-72F
I NEED A wiring DIAGRAM FOR a T-72 F TRUE FREEZER
    New Friend:
I need A wire diagram for a freezer mo.49f
Posted on Nov 04, 2012
  • Kim Taylor
    Kim Taylor Aug 29, 2018
    SO, WHATS THE ANSWER?
  • True Master
  • 4,656 Answers
Because I am not sure of your location in this world I will leave you with their home page. The Home page can take to any place near your location. Sea Breeze
Posted on Oct 21, 2009
  • 3 more comments
  • John Tripp
    John Tripp Oct 21, 2009
    Here is the main Link, Thanks, Sea Breeze
    http://www.truemfg.com/
  • John Tripp
    Here is a lead to contact questions that may be helpful for your location. If Europe this is for you HERE
    if I need to send you a different link please tell me your location....Sea Breeze
  • John Tripp
    TRUE FOOD SERVICE EQUIPMENT, INC.
    2001 East Terra Lane • P.O. Box 970 • O’Fallon, Missouri 63366
    (636)240-2400 • Fax (636)272-2408 • (800)325-6152 • Intl Fax# (001)636-272-7546
    Parts Dept. (800)424-TRUE • Parts Dept. Fax# (636)272-9471 • www.truemfg.com
  • John Tripp
    Hey, I emailed the Manufacture and requested the wiring diagram and their responsee was quite funny! They would like your serial number. Reason for my humor is here we always require the model number. Anyway it's in your hands from here. I have spent a lot of time on this and a simple TKS or note would be nice to know you have the information.Here below, Thanks Sea Breeze
    It will be helpful to have the serial number to be able to send you the
    proper diagram.
    Thanks.
    True Manufacturing.
    Technical Support Department.
    Omorales@truemfg.com
    636-240-2400
  • John Tripp
    And here is a copy of the return email to the MFG.
    I understand you perfectly. The serial number will come from someone other than me. I appreciate your help from here and will always ask with/for the serial number before referring you to the customer, Thanks Sea Breeze
4 Suggested Answers
SOURCE:
  • 1300 Answers
SOURCE: I NEED A DIAGRAM FOR DEFROST SWITCH ON T-72 F TRUE FREEZER
Go to www.truemfg.com and it will take you to their web site. They have a 24 hour, ask a tech a question. I could not find any wiring diagram on your particular unit but maybe they can help you via their tech hot line.
Good luck and hope this helps.
Posted on Apr 26, 2009
  • 1300 Answers
SOURCE: I need a complete wiring diagram for a T-72F True
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
This web site has the manual for all "T" series units. Check it out. should cover yours.
Good luck and hope this gets it for you.
Posted on Oct 24, 2009
bobicehouse
  • 1524 Answers
SOURCE: need wire diagram how to install 3 N 1 start relay
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
Posted on May 07, 2010
How to put hardstart kit in compressor GDM-72
depends if it is only a two wire hard start.. then wire it parelel with the run capacitor . place line to line and load to load . load goes to compressor and line to power which is usualy realy the neutral for a 120v compressor since the hot runs to a overload and straight to the compressor
Sep 13, 2013 | True 72 cu. ft. / 2039 liter Commercial...
Had a fire and need to rewire
Here is a PDF of Techinical information for all models of the True T-72F I will be here later should you have questions, Thanks Sea Breeze
Feb 09, 2013 | True 72 cu. ft. / 2039 liter Commercial...
True gdm12 evap fan runs all the time evev with the compressor off wiring seems not to have been touched
evap fans will run continuiously on this unit,it is normal. fans stay on to circuilate air evenly inside unit.
Sep 19, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Need wire diagram how to install 3 N 1 start relay on a true t12f freezer
Apr 29, 2010 | True 12 cu. ft. / 340 liter Commercial...
IM CHECK THE 72-F OF A CLIENT AND ALL WIRING IN THE EVAPORATOR ARE DISCONECT.I NEED A DIAGRAM
i think the best thing to do is call true mgf. and ask them to fax or email the diagram for you they might want a serial number as well
Toll Free: 800-325-6152
hope this helps
Mar 29, 2010 | True 72 cu. ft. / 2039 liter Commercial...
I like the wire diagram from 3 door freezer swich to lights inside
http://www.truemfg.com/index_en.aspx?language_id=1&event_id=401
Go to "Support" and then do the "Ask the True service Dept." They will need your model and serial numbers and they will send it to you.
Jan 11, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Long story but I had someone "attack" my T-72 Freezer and I'm trying to figure out what they did. I think they tried to replace the defrost switch with a non standard switch and stopped half way through...
Go to this web site. Be sure to have the serial and model numbers. You can request a wiring diagram from the tech line. This is most likely your best place to start. True uses a variety of different devices so I would do this first.
Let me know if I can be of more help after you get diagram.
Dec 07, 2009 | True 72 cu. ft. / 2039 liter Commercial...
Apr 22, 2009 | True 72 cu. ft. / 2039 liter Commercial...
True 72 cu. ft. / 2039 liter Commercial Freezer T-72F Logo
5,688 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Joe Palazola
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
