Have a Mitsubishi 55 rear projection tv model #WS-55511. When it's been on a while it shuts down. It won't come back on till it cools down. I did take the cover and plate off and when this happens I just put a fan blowing right into the guts. It only blinks once. Can anyone help?
NEXT TIME IT SHUTS DOWN: when green light goes out on THE FRONT OF THE SET: press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and then release.
This is the self check this model has---power light should blink a two digit code---for example--two blinks, a pause and two blinks and the set will repeat the error code about 10 times.
1 blink and then 2 blinks is NO ERROR DETECTED
2 blink and then 2 blinks is short protect
ETC.....Let me know if you get an error code and I will tell you what the problem is---hope you find 2,2 that is the most common and the most easy to repair.
SD TECH
