Game says new software needed to run this game but system upgraded after I joined network from 1.5 to 3.5 tried to update as requested now but after 2 hours it said update failed
just been fixing a window vista laptop with problems
Microsoft stopped supporting windows vista years ago
no updates or upgrades
you are at base service pack one
and computer should have been updated to service pack 3 years ago
from service pack 3 a windows 10 upgrade is possible
try an ethernet or usb wifi connection .
.see if the computer will run the way you want it
any windows vista computer is a x32 bit system
with upgrades can run x64
x86 is the current
if you are running anything higher than 32 or x64 software the computer will be slow sometimes freeze or shut down
vista came out same time as and dial up internet
and early broad band
vista can run office 95 but windows 2000 is stable
It's
easy to update/upgrade the Playstation Portable (PSP) 3000 system
software to firmware version 6.20. There are two ways to do a PSP 6.20update
- regular file download and network update. We did an update on our
pink PSP 3000 using the network update procedure since our place has
wifi.
Why did we choose network update in
updating our PSP firmware to ver 6.20? It's much simpler. Here is a
quick tutorial on how to carry out PSP 6.20 update using Network Update
(Method 1):
Go to Network Settings to configure your PSP WLAN by setting up an access point.
Under Network Settings, it would be best to choose Automatic to
simplify the process. Your PSP console will search for any wireless
network available nearby.
To Update System Software to the latest 6.20 firmware version, Go
to Network Update. Be sure your battery is full because the update will
fail if you turn off you PSP console or if the unit shuts down due to
lack of battery power.
Method 2: Download File To Update PSP 6.20 Firmware Using a PC. If you prefer to update your console using the download method, here are the simple steps in doing this:
Access to the Playstation Network is included in an old software upgrade. If you go into the Update function on your PSP menu, you'll be able to download and install the latest upgrade for your system.
This means that your console was not updated with the latest firmware to read Wave 4 games. To update your console, you have to join and sign in to Xbox Live and the system wuill automatically acquire an update to enable wave 4 games to run. Hope this helps.
Some game are compatible with the new xbox 360. They are called backwards compatible and you do need to flash upgrade the OS on the new xbox 360 system.
You need to go to the xbox website and go to support and download the flash update then burn it to disk and put it on the xbox to update the software. Again not all old games are compatible with the new xbox system. If your buying used games like I do make sure it says bc next to the title before buying them.
Here is the link to the upgrade
may need to clean the drive try qtip & alcohol if not try to run update again either your drive died or possibly you have corrupted blocks in the firm ware may need to send in to me or someone who has firmware tools
Firmware 3.60 is rather old, I would suggest upgrading to 4.01 or something in between before jumping to 5.02, this may clear the problem.
The network update feature of the PSP usually works better than when downloading via PC because there is less room for error. After you upgrade to a 4.xx firmware, try using the network update again.
Need to upgrade the firmware...sony needs firmware updates to play new games, add features...and attempt to slow piracy. Ro up grade your system go to settings and network update...if you do not have a wireless network to connect to you can download the updates and put on a memory stick from sony.com
