2002 Mazda Protege Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 Mazda Protege timing belt replaced and
2002 Mazda Protege timing belt replaced and engine ran for about 2 minutes and now is not fireing at all where do I go from here?
Anonymous
Level 2:
  • Expert 104 Answers
  • Posted on Oct 21, 2009
Anonymous
Expert
Level 2:
Answers
104
Questions
0
Helped
41648
Points
304
Scan PCM for codes. Check that timing is correct again.These DOHC engines are easy to install a tooth out. Start from the top of engine when installing timing belt on this type of engine it's the easiest way to do it. If you took CRANKSHAFT pulley apart make sure the pick up ring behind isn't placed in backwards.
What happens if car doesn't start after changing timing belt with a mazda protege 1999
If you did not have the bent valves replace then that may be the problem. If the belt has not broken then turning the engine over with the belt removed will bend valves. I suggest that you have a compression test done to eliminate the valve problem. Next is to recheck the cam shaft timing . next is to check the position and firing order of the distributor.
Ihave a 1996 mazda protege 1.8 litre engine. The car started a little hard but finally ran. Upon driving away it started runnung real rough so I parked the car. It smelled like raw gasoline inside the...
first of all with 3 cylinders 25lbs -1 100lbs. you have a problem with the vavles i think you have some bent vavles thats why low compression on 3 cylinders. check rockers or lifters but thats where it is foresure.
What are the timing marks for a 2000 Mazda protege 1.8L
I assume you are replacing the timing belt, so just wactch the youtube video at the link 1999 03 Mazda Protege 1 8L 2 0L timing belt replacement pt 1
Timing Belt replacement- two recomendations by mazda manual
they are good for well over 100k. If your engine is freewheeling (that is - if belt does break, no valve will hit the psiton), I would just keep driving it until it breaks or never does.
I am driving my 93 Villager until it breaks. over 150k right now, freewheeling engine.
As for cost, about $400 is my guess.
Ask your dealer service dept if it's freewheeling. check your owner manual too.
How to replace the serpentine belt of protege 5 2002, also need the routing diagram
Posted by Asker under 1997 Mazda Protege for their 2002 Mazda Protege 5.
Both are included Below
Click on the following free direct Link. It has the Belt Diagrams for the 1997 Mazda Protege with either the 1.5L DOHC In-Line 4-Cylinder or 1.8L DOHC In-Line 4-Cylinder Engines; along with various engine options (AC/No AC, etc.). Included are Instrucional Diagrams for loosening (for removal) and tightening (for replacement) using the Adjustment and Locking Bolts/Nuts.
http://www.2carpros.com/car_repair_information/year/1997/make/mazda/model/protege/1997_mazda_protege_drive_belt_routing_diagram.htm
Click on the following free direct Link. It has the Belt Diagrams for your 2002 Mazda Protege 5 2.0L DOHC In-Line 4-Cylinder Engine; along with various engine options (AC/No AC, etc.). Included are Instructional Diagrams for loosening (for removal) and tightening (for replacement) using the Adjustment and Locking Bolts/Nuts.
http://www.2carpros.com/car_repair_information/year/2002/make/mazda/model/protege5/2002_mazda_protege5_drive_belt_routing_diagram.htm
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
1helpful
Timing Belt on 2002 Mazda Protege
every 90,000 to 100,000miles and yes it is strongly recomended to replace the water pump with it
6helpful
How much should I reasonably pay to replace the Timing belt in my 2002 Mazda Protege 5?
replacement of timing belt $350-$500. aftermarket shops will try to sell you a package containg a belt, water pump, and tensioner pulley. the dealer will just replace the belt, they might recommend to replace the water pump if there are alot of miles on the car, they will also inspect the pulley for wear.
Top Mazda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Mazda Expert? Answer questions, earn points and help others
