Question about Moen & Replacement Cartridge
How do I pull a moen single lever kitchen cartridge out that is old and stuck?I removed the horseshoe shaped clip. When I pull the valve stem, it doesn't budge.
  • 127 Answers
There is a little plastic tool that comes with a new cartridge....you use it to turn the cartridge back and forth....breaking the seal that has formed between the rubber on the outside of the cartridge and the inner wall of the valve. After doing that you should be able use a pair of channel locks to pull the cartridge out.
Posted on Oct 24, 2009
SOURCE:
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    No Hot water coming out when single handle on hot water side.Cold water comes out fine. Water in the lines leading to the taps, but no hot water coming out. This is a bathroom faucet Moen single handle.
    Cartridge removal is a simple matter of exposing and pulling out the old cartridge. Before getting started, turn off both water valves underneath the sink and allow the water to run until the line is clear. Using a screwdriver, gently pry off the cap on the lever of the faucet handle to expose the cartridge. Remove the U-shaped retaining clip that holds the cartridge in place and pull the cartridge out. If dirt or residue makes removal difficult, use a Moen cartridge puller to assist you. A cartridge puller fits over the cartridge and gives you greater pulling power.
    Soak the dirty cartridge in vinegar for four hours and replace.
    If cleaning the cartridge does not work, call the Moen Helpline at 1-800-465-6636 or Customer Service at 1-800-465-6130 to order a free replacement. Locate the part number on the cover page of your instruction manual. If you no longer have the manual, look on the underside of the spout.
    Feb 08, 2011 | Moen Monticello Single-Handle Kitchen...
    Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
    Moen has a diverter built in that will need to be replaced.
    use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
    take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
    use a non silicone faucet lubricant when putting back together
    Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Have a Moen single lever kitchen fawcet with seperate sprayer and it drips. I poped off the center cap on top of the fawcet and can see a cartridge but don't know how to remove it. It's brushed chrome.
    Most MOEN single handle faucets use the same cartridge, the 1200 or 1225. If you have it apart enough to see the top there should only be a few more parts to remove to get at the stem ie the handle and cap. Once there you should see the horse shoe clip that holds the stem in. Once you slide the horse shoe clip off, the stem should be ready to go. Now sometimes these will come out easily, but most of the time they are a little tough. You can use a crescent wrench and gently turn the cartridge at the ears where the horse shoe clip was removed and this will loosen the cartridge, then you can use the handle or what ever you can grab the stem with to pull it out. FYI a lot of the home improvement stores carry a MOEN cartridge puller and they make it a lot easier. After cartridge is removed install new one and your done. DONT forget to turn off water before you begin. Hope this helps.
    May 13, 2010 | Plumbing
    I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
    you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
    Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Need to replace cartridge in single lever moen kitchen faucet .Walk me through the process.
    Turn off water
    Remove the handle with an allen wrench, usually 1/8".
    Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
    Wiggle out the old cartridge with the channel lock pliers.
    Clean all innards with WD-40.
    Reverse procedure
    Dec 12, 2009 | Moen Plumbing
    Replace the cartridge for a moen shower
    It is stuck, they come out very hard and a puller is made to make removal easier.
    Nov 12, 2009 | Moen & Replacement Cartridge
    Water leaks from around the stem when I lift the water handle. What to do? It doesn't drip from the tap, but from around the stem part - sometimes quite a lot of water. Can I repair this myself? It's a...
    ur cartridge needs service or replacement u can turn off water supply remove lever and retaining nuts pull up cartridge and inspect the o rings for debris and or damage if good inspect cartridge for damage if looks check gaskets/o-rings in stem for same add a little vasline around o-rings and reinstall test for leak if leaking still replace all o-rings or if cartridge order and replace
    Nov 03, 2009 | Moen 87530 Touch Control Single Handle...
    Moen kitchen faucet. I changed the cartridge but
    Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
    Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Moen & Replacement Cartridge  Logo
    354 people viewed this question
    Top Moen Home Experts
    Mike
    john h
    Andrew Bugbee
    Are you a Moen Home Expert? Answer questions, earn points and help others
