My Upright Freezer was plugged and running, after running for 4 hours the Freezer turned off and tripped my circuit breakers. I reset all my breakers and now my freezer doesn't turn on. I am being told there is a fuse or a reset button on the freezer. I can not locate this fuse or button.
It probably has a circuit breaker located on the bottom of the fridge, behind the front filter. Also try looking inside the refridgerator side at the top. It may be red colored to indicate it is safety-related. Just push it in - but don't be surprised if it trips again.
WARNING: RESET ONLY ONCE TO AVOID A FIRE OR ELECTROCUTION SITUATION.
You may have an internal problem, in which case the freezer's circuit breaker is your best friend!
Note that the self-defrosting freezers have a timer that shuts them off periodically so they can defrost. Sometimes the timer does the defrosting in the middle of the day, giving the appearance of a failure. This could be your problem.
